Greddy Ti-C Exhaust problem
Old May 12, 2008 | 03:16 PM
whitelancerGTS's Avatar
hey guys,
i recently purchased a Greddy Ti-C exhaust, at first, it was amazing. i absolutely loved it. However, recently, i've been hearing some raspy noises while i accelerate. my throttle response is a little weaker than before. the sound occurs randomly.
i am thinking it is a leak somewhere. perhaps at the bolt on point. can it be anything else?
let me know asap guys!
D
Old May 12, 2008 | 03:28 PM
evo_soul's Avatar
you can check the junction point where you bolted it on, it should be ok. I think there is also a gasket in there (cant remember) if there is then its wise to replace it when you do the upgrade if your over 10,000 km.
As for the rasp, this will have to do with the diameter size piping used and canister configuration. You may potentially lose low end TQ with the trade off of getting mid to peak performance gain. It will be feel different. Only real way to know is to dyno it. let me know if you want to explore that option.
Old May 12, 2008 | 06:27 PM
the greddy uses the lancer's stock gasket. im at 25000km. maybe i should change it. how much do u know?
Old May 13, 2008 | 07:50 PM
rav's Avatar
rav
hmm quick question: I thought there wasn't a gasket on the lancer (well I didn't have one when I took off my stock and put RRMs).
Old May 14, 2008 | 08:43 AM
cRc`22's Avatar
their isnt one at the axleback point but there is one from the header to the cat. unless GReddy came with one like the Injen one
Old May 14, 2008 | 12:56 PM
Blacksheepdj's Avatar
Check for exhaust leak, then come back and post if you need more help. I'd bet it's leaking somewhere.
