easier way to tighten the altenator belt??
Old Jun 7, 2008 | 09:01 AM
donnie25's Avatar
I just put one on, it was a b*** to tighten it. but it still makes a chirp noise once a while. Any easier wat to tighen it??
Old Jun 16, 2008 | 09:42 AM
blaze_125's Avatar
When I replaced my alternator a few weeks ago, the tensioner bolt broke when I took it off.
I put the alt back on without it(just like on a Honda).
Take a pry bar, put it behind the alt, pry it up to desired tension, then tighten the bolt at the top of the alt.
On the alt, you should have 3 bolts prior to any work done on it.
1 at the bottom (the pivot one)
1 that acts as the tensioner
1 at the top to keep it from moving
Old Jun 17, 2008 | 12:24 PM
mcgarvey's Avatar
It may work for now but over time it will slowly lose tension. Just replace the jack screw. I don't understand how it broke in the first place?
Old Jun 17, 2008 | 01:31 PM
atilla's Avatar
those bolts do strange things. my power steering/AC belt tensioner was all sorts of jacked up. i just drove without the belt on until i had time to get the replacement parts from ...but you don't exactly have that luxury with your alternator belt.
Old Jun 19, 2008 | 12:46 PM
blaze_125's Avatar
I doubt it will if it's done properly, otherwise other manufacturers wouldn't do it at the factory. I'll see with time I guess.
