Idles keeps going higher and higher
Old Jun 9, 2008 | 10:49 AM
samurat's Avatar
I hope this has not been posted before I did do a search but couldnt find any thing on the rpms going while idling. Most started high then went down. My 05 runs fine for the first 5 min of normal driving and after that it just keeps going higher from 1000 to 1500. It does this all the way up to 4000 rpms. I have no check engine light on. My car is stock besides the cold air intake.
thanks.
Old Jun 11, 2008 | 10:14 AM
TougeOZ_04's Avatar
foot off gas
i kid
did u reset it after the CAI install?
Old Jun 24, 2008 | 12:49 PM
ReaverOfDtown's Avatar
^^x2. Unhook your battery and let it sit for about 5 minutes or so, then reconnect it. I had a couple problems with my Celica after a CAI install and that fixed it
Old Jun 24, 2008 | 01:00 PM
ambystom01's Avatar
If that doesn't work, check for air leaks, clean the TB and make sure the throttle cable isn't touching the valve cover.
Old Jun 24, 2008 | 05:08 PM
mcgarvey's Avatar
If all the above fails replace the IAC valve. But I'm guessing disconnecting the battery will fix it.
