engine build
Old Oct 2, 2008 | 11:57 PM
ThunderOZ's Avatar
Do you plan to use only pump gas or run alcohol/meth as well?
Old Oct 3, 2008 | 12:00 AM
03LancerUTI's Avatar
prolly just pump gas but maybe meth down the road well more so a month or two after the install depending on how much cash i have after this.
Old Oct 3, 2008 | 12:07 AM
ThunderOZ's Avatar
Well don't forget about a good tune though but I've seen members here sit around 17-20 psi... I've only heard of one other lancer that went around 22+ and he's using alky injection. Said he wasn't sure if it was needed but it helps...
Old Oct 3, 2008 | 12:12 AM
ok cool thanks. does RRM tune?
Old Oct 3, 2008 | 12:17 AM
ThunderOZ's Avatar
Call them up... From the guys I've seen run high boost like that, they've used a stand alone engine management system or something like the greddy emanage ultimate...
Old Oct 3, 2008 | 12:50 AM
my car has 93k miles on it and i have a CBE magnaflow, and the AEM CAI. would it be worth it to buy the RRM turbo kit and run like 5psi or what not. would it be a good investment and just swap the turbo when i swap the motor or would it be better to wait and know im not gunna blow a head gasket or blow the rings?
Old Oct 3, 2008 | 01:11 AM
ThunderOZ's Avatar
Well I'm finishing up a custom 16g kit(came up a 2-3grand cheaper than RRM's kit) and I have 143k on the motor/trans... I'm going to put it on and hope it lasts until I can build the motor next year...
Old Oct 3, 2008 | 10:45 AM
ambystom01's Avatar
Why not buy a new motor, build it up and then swap it in?
Old Oct 3, 2008 | 10:55 AM
ThunderOZ's Avatar
That's my plan but I need money to buy a new motor If I can find one, which is a bit harder around here than what it sounds, I'd do that...
Old Oct 3, 2008 | 11:42 AM
so u think a turbo kit would last on my car with low boost for about a year or so until i swap it in?
Old Oct 3, 2008 | 04:49 PM
Complink's Avatar
^well i think you will be fine at no more than 6 or 7 psi as long as you have taken care of your motor for those 143k miles. i.e. changed oil as per specs.
Old Oct 4, 2008 | 07:31 AM
drucea's Avatar
I agree, if you've taken good care of the motor for all those miles, a turbo shouldn't give it any problems on low boost. I would say if you don't mind the hassle of installing the turbo kit twice, put it on this motor at around 5-7 psi, then switch it over to the new motor when it's ready. It will be such a big difference from an intake and exhaust, you probably wouldn't want to ever drive a non turbo lancer again.
Old Oct 4, 2008 | 09:50 AM
Jehuty's Avatar
What's up with your turbo drucea?
Old Oct 4, 2008 | 10:45 AM
4g94T's Avatar
i agree... if you dont mind double the work, but after the first install it should be easy if you were to do it again.
...and im never buying a NA car again
Old Oct 4, 2008 | 06:47 PM
OZ Rally's Avatar
I'm planning on buying a used (low mile) 4g94 and port it myself (head, intake mani, and throttle body) then get the forged rods and pistons. That should be done by next summer and then swap it and go turbo by next winter!
Can't wait!
