Lower temp thermostat?
Old Nov 6, 2008 | 01:56 AM
ziftawi's Avatar
I was reading through the service manual and it states that 2 factors that affect the engine timing is the temp of the air going into the engine and the coolant temp, it says by having a colder coolant temp you get more advanced timing. Has anyone tried this or are there cons to doing this.
Old Nov 8, 2008 | 08:05 AM
CamShaft's Avatar
your engine is designed to run optimally at full engine temp Ie) 170-180 degrees. Running cooler will just waste gas and end up putting premature wear on your engine. I wouldn't recommend doing this to get some more advanced timing. Get a ECU flash or other mods.
detroit pistins
Jul 26, 2014 12:46 PM
BriK
32
Aug 27, 2012 06:30 AM
Kevon
Apr 20, 2012 09:32 AM
VGergo
Dec 9, 2010 04:24 AM
05BlackEVO
May 13, 2006 12:07 PM
