Something weird happened after my first oil change...
Old Nov 14, 2008 | 02:12 PM
Peebz's Avatar
After my first oil change my engine sounds a bit louder, like I got a aftermarket air intake for it. Anyone else noticed that?
Old Nov 14, 2008 | 02:29 PM
lancer0220's Avatar
did you do the oil change or was it done at a shop?
if it was done at a shop this is most likely what happened, the guy did the routine check on fluids and tire pressure and air filter check.
when he opened the box to get the filter out he opened it too much, unlatching the latches at the bottom, this is very unnoticeable, he then put the filter back in and closed it up.
the loud noise you are hearing is your airbox not properly sealed. it is a pain to get it to close right .
if you took it to an oil place this is what happened.
Old Nov 14, 2008 | 10:53 PM
WangMan's Avatar
i personally think the shop used some high decibel oil which would obviously make your car louder
EvoKnievel77
Jan 27, 2017 07:54 PM
JustAnoterEvo
Evo X How Tos / Installations
13
Jul 3, 2013 04:41 PM
stlgrym3
Jun 6, 2010 09:45 PM
Tommy boy
Canadian Forum
11
Jan 17, 2009 10:42 AM
Slovak
Nov 9, 2005 12:59 PM
