02 Oz Spark plugs
Old Jan 10, 2009 | 04:12 PM
luischav3z's Avatar
02 Oz Spark plugs
Well im going to replace the spark plugs for my first time on the lancer and I dont know which ones to get I was thinking of getting the NGK iridium ones which are gapped at .044. I have heard that you shouldn't regap iridium plugs but as the manual states spark plug gap should be .039 to .043 in would it matter if I just put the plugs at .044?
Old Jan 10, 2009 | 06:27 PM
mcgarvey's Avatar
Yes that's fine. It's true that iridium plugs should not be regapped. The difference between .043 (upper end of the spec) and .044 is so miniscule you would be hard pressed to see it even under a microscope.
Old Jan 11, 2009 | 08:37 PM
boondoc's Avatar
I'm in the same boat. So the NGK's are fine to use?
Old Jan 11, 2009 | 10:21 PM
Lucas03ES's Avatar
2003 MITSUBISHI LANCER 2.0 L4 FI
Spark Plug Part No. Stock No. Plug Gap
Standard BKR5ES-11 2382 .044
V-Power BKR5E-11 6953 .044
G-Power BKR5EGP 7090 .044
Laser Platinum PFR5J-11 * 4642 .044
OE Laser Iridium IFR5E11 ^ # 7994 .044
Iridium IX BKR5EIX-11 5464 .044
I used just the standard BKR5ES-11 as it is the stock plugs in our cars. Using the iridium plugs with a +.01 difference will not be noticeable at all.
Evoguy!123
Jul 20, 2016 07:26 AM
melonfarmer
Jun 13, 2015 07:05 AM
kambodianboi
Oct 6, 2010 08:13 PM
02-Lancer-Es
Lancer Engine Management / Tuning Forums
Jun 1, 2008 09:15 PM
rEvolution420
Oct 5, 2007 08:31 PM
