quick question RRM headers
Old Jan 21, 2009 | 06:50 PM
Dwalk08's Avatar
I have already used the search button and I cant find the answer so here is the question. I purchased the RRM headers today and magnaflow high flow cat and I wanted to know if a new downpipe comes with the headers? And what about new gaskets? I know the CEL eliminator does but I was curious about these other things. Thanks.
Also question about the order of parts...
Headers to downpipe to high flow cat to 2.25 inch catback to the flowmaster exhaust?
Old Jan 21, 2009 | 06:56 PM
ambystom01's Avatar
I don't believe so.
Old Jan 21, 2009 | 07:04 PM
zbailey129's Avatar
You will have to purchase new gaskets, and there is no down pipe included.
Old Jan 21, 2009 | 08:05 PM
doctorjon's Avatar
I believe eBay sells 3 inch downpipes now. Just order a new exhaust manifold gasket from your local autoparts store or get it from the dealership.
Old Jan 21, 2009 | 09:59 PM
Dwalk08's Avatar
okay cool thanks I will pick up a set of new gaskets and I will search for a new downpipe in the meantime I will just bolt up my stock one until I find a new one to order. thanks
Old Jan 21, 2009 | 10:02 PM
Dwalk08's Avatar
yeah i just searched ebay and found a 3 inch downpipe for 90 bucks, part number for my 06 lancer was MN180782. The listing mentioned intermediate pipes and muffler?
Old Jan 21, 2009 | 10:05 PM
02-Lancer-Es's Avatar
Or you can also buy a kamikazi header that is a header-downpipe and is 2 1/2 inch .
Thats what i have
Old Jan 21, 2009 | 10:09 PM
Dwalk08's Avatar
yeah i saw that too..can you cancel an order through RRM ?
Old Jan 21, 2009 | 10:11 PM
Dwalk08's Avatar
will it matter if I have a 3 inch down pipe but the rest of my piping is 2.25, i mean will the DP bolt up the same with the rest of the exhaust?
Old Jan 21, 2009 | 10:14 PM
Hmm not sure , might because the bolts will not line up with the smaller piping .
Old Jan 21, 2009 | 10:24 PM
Dwalk08's Avatar
the listing says that no modification is needed that this is a direct bolt on replacement so I guess I have a choice to make of whether to use the stock DP or try out this one.....I would most likely have to cut off the end anyways because I have the weld-on high flow cat and my exhaust shop can make an adapter to go from the 3 inch DP to the 2.5 cat so....
http://cgi.ebay.com/ebaymotors/02-07...1%7C240%3A1318
Old Jan 21, 2009 | 10:26 PM
Dwalk08's Avatar
either cut it off and weld on the cat directly, or they could use the bolt plate from the oem cat and weld it to the high flow cat so it would mount up to the DP...I dunno, atleast i have a few days to figure this crap out
Old Jan 21, 2009 | 10:31 PM
lol
The link doesn't really look like a 3 inch , more like 2 1/2 and if it is then thats why its a direct bolt on .
Old Jan 22, 2009 | 09:32 AM
doctorjon's Avatar
That is just a stock photo. I'm sure the one you'll be getting is the real deal and should be able to fit your catalytic converter. It doesn't look long enough to delete your converter. The Kamikaze headers is a 4-2-1 header i believe. The RRM headers are just a 4-1 to give you power in higher RPM range and the 4-2-1 is for lower RPM range.
Old Jan 22, 2009 | 09:45 AM
The Kamikazi is a 4-1 also
gui dube987
18
Apr 24, 2015 05:21 PM
gui dube987
35
Feb 13, 2014 12:09 PM
04mralliart
Sep 6, 2012 03:43 PM
newbiewonkenobe
Lancer Engine Tech
21
Dec 15, 2005 07:07 AM
02lancerls
Lancer Engine Tech
27
Dec 11, 2005 10:08 AM
