4G93T swap
Old Feb 17, 2009 | 12:08 PM
GLancezOZoo's Avatar
4G93T swap
has anyone heard of the 4G93T swap in the oz rally?
Old Feb 17, 2009 | 01:10 PM
OZ Rally's Avatar
Good luck finding one.
It's better to Turbo a 4g94 than a 4g93.
Old Feb 17, 2009 | 01:22 PM
cincy's Avatar
6A12 engine baby!!!
Old Feb 17, 2009 | 02:19 PM
OZ Rally's Avatar
4g63 baby! lol
Old Feb 17, 2009 | 04:51 PM
Revolution I's Avatar
im kind of new
in puerto rico they are putting 4g93 pistons on the rods of the 4g94! and the head of the 4g93 on the 4g94 block.
Old Feb 17, 2009 | 04:55 PM
OZ Rally's Avatar
So do they see any performance gains?
Old Feb 17, 2009 | 05:32 PM
*02Lancer*'s Avatar
Why are the putting the piston/rod assembly into the 4g94? I can see the head because of the cam/springs other then that they are the same.
Old Feb 17, 2009 | 06:28 PM
bluelancer20028's Avatar
rods will lower comp
Old Feb 17, 2009 | 10:53 PM
*02Lancer*'s Avatar
Why would you want to loose HP/TQ? I mean if you are crazy boosting I can see it but N/A or low boost no way.
Old Feb 18, 2009 | 01:57 AM
Demon_ni2's Avatar
^^ditto. ya but there kinda stupid over there. we all know the pistons and rods from a lower hp car will up the hp/trq of a newer car. duhhh..
nah but seriosuly.. why would u want a older mirage motor instead of the lancer motor. just upgrade the springs and a new cam, and get some forged pistons and rods.. would be 10x better then another stock motor with stock swapped parts.
Old Feb 18, 2009 | 11:22 AM
cincy's Avatar
Rods dont change compression ratios LOL
Old Feb 18, 2009 | 12:30 PM
ThunderOZ's Avatar
Have you seen the times some boosted mirages have run compared to lancers?
Old Feb 18, 2009 | 02:13 PM
cincy's Avatar
But isnt that more of a weight issue than power????
Old Feb 18, 2009 | 02:32 PM
ThunderOZ's Avatar
Whats the weight dif? About 300lbs?
Old Feb 18, 2009 | 03:24 PM
cincy's Avatar
A 2dr mirage is under 2260lbs and the lancer is 2650. 400lbs takes a lot less to get moving
