4G93T swap
Old Mar 28, 2009 | 04:46 PM
  #31
Punz247's Avatar
Originally Posted by KillahB
Make sure you're comparing apples to apples and oranges to oranges.
4G93 were the 1.8L engines that are being referenced in this thread. You are talking about 4G63 which is another ballgame altogether. They were never 1.8L stock at all.
If you mistakenly wrote 63 and meant 93, then I dont know what the PR guys are doing, since the 4G93 pistons are 0.5 mm smaller than the Lancer block. We explored possibilities of hybridizing when I was still 4G93 but it wasn't as easy as it seemed so I abandoned it quickly and just went with forged Lancer pistons in the Mirage block (upped my displacement to about 1.9L).
Yea i did hit the 63 instend of 93, but you understood what i was talking about.... They must of sleeved it or something. I cant think of no other way to shove 1.8 pistons in a 2.0 block.
Old Nov 24, 2009 | 01:25 PM
  #32
jwick76's Avatar
ok, so i have a question. I jsut got a 4g93 cylinder head from a used parts place, and they swear it will bolt up fine on the 4g94, or I can return it. Now, that engine was somewhere around 1800cc and the 4g94 in the '03 is 1999/2000cc. so that being said, is this head going to improve my low end and kill some of my barely existing top end? I haven't pulled the 4g94 head off yet to compare, but I'm assuming that i should port this 4g93 head....or does that even matter significantly since the heads are pretty much the same? Any ideas if I'll run into issues with the intake manifold?
Basically, anyone try this before? Anyone know of any threads I can check out? I've been searching for 4g93, only found 4 or 5 threads so far most of them dealing with the intake manifold...this is the most involved one that stays on topic.
If everything works for a short-term fix, I'll just keep the 4g94 head and get that ported and polished and built up for later
Old Feb 28, 2018 | 07:27 PM
  #33
mark1997's Avatar
help me...
Hi guys, im from the philippines and i was wondering is it har to tune a 4g93t engine? i got my lancer gsr and engine swaped it into a 4g93t. (before it was a cyclone engine.) was wondering is the parts here available? and swaps are easy? please help.
Old Sep 12, 2020 | 11:24 PM
  #34
RobGinSki's Avatar
I just got my hands on a 4G93T
Getting a parts list together So I can order everything online and get this installed in the 03. Got tired of the SOHC turbo sooooooo DOHC turbo it is!
chris#1
Lancer Engine Tech
17
Jun 20, 2020 12:08 PM
taavisev
Australian Forum
Jun 15, 2020 11:53 AM
mirage 4g93t
Apr 30, 2008 08:41 PM
abcarino
Lancer Engine Tech
Jul 25, 2007 02:29 PM
decoder
Nov 26, 2003 06:35 AM
