Bad Valve Guides
Old Jun 13, 2009 | 06:05 PM
4g94T's Avatar
You wouldn't be able to raise the rev limit anyways.
The rev limit in ecuflash hasn't been properly defined for our ROMs.
But I'm sure if you switch over to the EVO 8 ecu you will be able to
Old Jun 13, 2009 | 06:09 PM
senate6268's Avatar
Originally Posted by jrelyea828
i heard you can safely rev it up to 6800, you arent limited to 6800, but i guess people dont recommend going past that. and thanks for the all the help. i meant cam not cams. i wish it was a dohc haha.
At 7000rpm, 4G94 piston speed is around 22.35m/sec. So definitely rev that high at your own risk without stronger internals.
Old Jun 13, 2009 | 08:33 PM
imalancerman's Avatar
Ah ok then. Basically stay away from that. Its cool. Im happy with my 6250 redline......I guess. Lol. I couldnt take advantage of it anyway without more mods. S'all good. Thanks alot for the info.
Old Jul 31, 2009 | 09:22 PM
jrelyea828's Avatar
Well... money is incredibly tight now, so I was curious as to if the time its going to take to replace the valve guides is actually worth it. I've been reading up on a dohc head swap but clearly i can't afford it at the moment. Ive seen ported and polished heads for sale for a grand or more, and thats a little out of my league. What would be the smartest thing in your opinion for me to do? Should i just sell the car the way it is, or is it worth fixing. because if i can manage to get it repaired i plan on building it up, but i need a cheap fix for the time being.
Oh and also, Im so sick of adding oil to it every other week, so I need to do something with this thing.
Old Jul 31, 2009 | 09:56 PM
get another head off of car-part.com. I got my mirage head for 140 shipped. I then gasket matched it myself. I know there are lancer heads for cheaper but I wanted the mirage cam.
Old Jul 31, 2009 | 09:59 PM
JRR's Avatar
JRR
last i knew im my area i can get an entire 4g94 with like 60k on it for $400 bux i think from car-part.com
Old Jul 31, 2009 | 10:08 PM
That is also totally dependant on area. Closest one to me through car-part was 700 bux. Shipping charges will kill you on an engine if you have to buy out of area too. Shipping on a head is 40 bux.
piponpi
Sep 9, 2016 07:33 PM
kylefowlie
Feb 22, 2016 11:54 PM
BogusSVO
Dec 7, 2012 04:49 PM
GregGSC
Jul 10, 2012 05:03 PM
