RRM Timing Module Question
Old Aug 23, 2009 | 10:02 AM
RTW EVO's Avatar
I just bought and installed the RRM Timing control module and I have a question with regards to mounting it. As you can see in the pic, right now, I have it mounted with some heavy duty double sided tape and zip tied like a sadistic bondage fan. The question is, is it enough? Should I drill into the frame and bolt/screw it down? It's really secure right now, but I'm worried it might come loose one day... What has everyone else used to secure it?
I did some searching but couldn't find what any one used to secure it.
As far as reviews - it is by far the best mod I have put on so far. The acceleration is nice and linear now, no more jerking as I depress the gas petal. And it now pulls all the way to the top of the RPM band, instead of puttering out as it did normally. I can't say I gained that much HP/TQ as I have no immediate access to a dyno, but it definitely feels more powerful.
Old Aug 24, 2009 | 05:38 PM
LegendsoWicked's Avatar
Since your using zip ties anyway...see that plastic cover right in front of your box there? I mounted mine under that-looking at your pic move to the right in the gap next to the snap. Plenty of room and you can use the wholes there to tie it down. I did mine like that, its clean, secure and hidden. And places you cant see is a good thing. I cleaned up the wire by tracking an existing one so if you didnt know any better it looks stock.
