Tuned Timing Maps
Old Feb 22, 2010 | 11:54 PM
03lances's Avatar
Tuned Timing Maps
Sup guys so I seen a thread like this in the evo thread and thought we could start one here. If you want to contribute post your tuned timing map and also your car and setup.
Here is mine:
2003 Lancer ES running a custom 16g turbo setup @10psi
Old Feb 23, 2010 | 09:07 AM
ThunderOZ's Avatar
How much load are you actually seeing during a pull?
Old Feb 23, 2010 | 09:22 AM
03lances's Avatar
I am running an evo maf so right now 152 is the highest
Old Feb 23, 2010 | 07:17 PM
03lances's Avatar
Nobody wants to contribute?
Old Feb 23, 2010 | 07:27 PM
JRR's Avatar
JRR
im runnig the stock evo timing all the way thru except for like the first 2 columns where im running the base lancer
Old Feb 23, 2010 | 08:48 PM
03lances's Avatar
Interesting... whats your load values hitting?
Old Feb 23, 2010 | 09:32 PM
JRR's Avatar
JRR
dont know. i dropped my tuning computer and now the lcd is all screwed up, but i just ordered a new used one from ebay so that will become my new tuning comp. much faster and a lot more ram, plus more usb ports to hook crap up to.
Old Feb 23, 2010 | 09:45 PM
03lances's Avatar
Oh cool lemme know what your load is and your knock counts when you get a chance I like to compare
Old Feb 23, 2010 | 09:52 PM
03lances's Avatar
Wow I just looked up one of my stock evo ecu roms and I would be running a full 7 degrees more of timing at peak torque then what I am running now if I used straight evo timing hmm.. make me wonder how much knock I would see if I did this.
Old Feb 24, 2010 | 12:21 AM
ThunderOZ's Avatar
Whoa, I must be off somewhere b/c I think I am only hitting like 120 at 7 psi with my 501 maf.
ThunderOZ's Avatar
Are you getting any knock?
Old Feb 24, 2010 | 12:22 AM
EvoKnievel's Avatar
93 octane?
Old Feb 24, 2010 | 12:29 AM
4g94T's Avatar
your load values will be different if you've changed the MAF size value
Old Feb 24, 2010 | 01:00 AM
03lances's Avatar
Yup the evo maf has alot higher maf size than the 501 (257.7 for 501 vs 357.5 for the 399) only have 92 octane here mainly just 1s and 2s for knock right now but I was hitting more whp hitting only 96 load on my stock maf, its a pain trying to tune for this load without an evo ecu.
Old Feb 24, 2010 | 07:59 AM
nestoledo's Avatar
the timing goes of the hand with afr, for that reason for afr of 12,5 you have a timing map and for afr of 11,0 the timing map is different.
