2 step on the lancer?
Old May 11, 2010 | 12:18 PM
bzmotoninja83's Avatar
ok, a friend of mine has a 2step msd box on his 97 eclipse and might sell it. if i buy it how the heck would i wire the damn thing??? he has 1 coil i have 4. also i was thinking about taking an eclipse coil and using it in the lancer. i know i need to get wires that would fit. what wires would go to which area on the plug? also is there any power difference between a round plug coil and a square plug coil from the eclipse? thanks in advance for your help, if at all.
bill Z
aka invader Zim
Old May 11, 2010 | 01:06 PM
senate6268's Avatar
There is no need to change your ignition system just to gain a 2-step. If you want a 2-step, and have a manual transmission Lancer, then flash an Evo ROM onto your ECU and use the 2-step feature they have. Otherwise, you'll be redoing your entire ignition system with wires, coil, ignitor, and that MSD box that will give you zero power gain.
Old May 11, 2010 | 01:38 PM
RoadSpike's Avatar
Just as a side note the auto transmission isn't possible to do a 2 step process because of the way the transmission works. We can not fully disengage the transmission to rev up to 2 step. So the best you can do is get the transmission up to stall speed and use a transmission brake.
Old May 12, 2010 | 06:00 PM
so let me get this right, i can 2step on the oem ecu that my lancer came with after a reflash? or do i need to get an evo ecu first? also i read some where else that with the ecu swap, in order to get the 2stp to work, after i flash and swap the 2 wires, that i need to also jump a wire from "x to x" location for the clutch switch. at any rate, anyone have a tactrix cable they wanna sell 4 cheap? or just help me with the hacking and tweaking?
Old May 12, 2010 | 06:10 PM
senate6268's Avatar
Correct. If you flash an Evo ROM onto your ECU and run the missing wire from the clutch position switch to the ECU (factory on Evo, missing on Lancer) you can run a 2 step with your OEM ECU.
Old May 13, 2010 | 06:09 AM
so, what is the 2step set at? 3k? i just want this not only to show off but to decrease my time in the 1320
Old May 13, 2010 | 08:29 AM
senate6268's Avatar
You can set the limit to whatever you want if you use TephraV7. You can also setup NLTS if you have a heavy enough clutch.
Old May 13, 2010 | 10:24 AM
what is "NLTS"? also, anyone have a cable 4 cheap? i have a laptop already.
Old May 13, 2010 | 10:51 AM
03lances's Avatar
NLTS is "No Lift To Shift" an awesome little feature that allows you to shift gears without lifting your foot off the throttle by creating a temp. rev limit as soon as you push in the clutch
Old May 13, 2010 | 01:16 PM
qaz003's Avatar
a little confused...what is a two step???
Old May 13, 2010 | 01:51 PM
senate6268's Avatar
A 2 step is essentially a rev limiter that you setup for when you are stopped. You might also think of it as launch control. With the gas pedal depressed the engine will only rev to say 3500rpm, for example, and allow you to release the clutch and go. There is an upper RPM and a lower RPM that the engine bounces between.
Old May 13, 2010 | 02:40 PM
qaz003's Avatar
icic...all makes sense now...lol
Old May 13, 2010 | 07:58 PM
ok ok. cool stuff.
so, is there anyone near richmond va. that has a cable i can buy???
Old May 13, 2010 | 09:44 PM
*02Lancer*'s Avatar
what is TephraV7?
Old May 13, 2010 | 09:59 PM
from what i gather, its a certain version of an "evo" rom that is recommended to use for your oem lancer ecu. maybe the most compatible rom for a usdm 02-03 lancer
