RRM Pulley Install Help
Old Jun 24, 2010 | 10:15 PM
maverick31210's Avatar
went to install the pulley and had some issues;
for starters, the alternator would NOT budge, i loosed the two bolts up top and nothing. went down below and tried to loosen the third bolt and it would not move one bit.
then i got to tighten the power steering pump back up and when i tighten the bolt, it moves to the right! it would not stay straight and tighten up properly. i tightened it as best i could but here's how it's looking. how do i get that bolt to line up straight and not move to the right as i am tightening it?
Old Jun 24, 2010 | 11:52 PM
03lances's Avatar
I suggest you pull that pulley off and inspect that adjusting bolt and the stop bolt to make sure its not bent. If its fine then you should be fine to reinstall it then just make sure its lined up.
Old Jun 25, 2010 | 12:07 AM
how would i pull it off to inspect, it's pretty hard to see whats happening down in there.
Old Jun 25, 2010 | 01:38 AM
03lances's Avatar
Well first loosen the bolt that is in the center of the pulley, then loosen that bolt that is angled until you can pull the belt off. Then the bolt in the center of the pulley take that one completey all the way out. That bolt is threaded into the other one so after you pull that one all the way out you can take off the pulley and the adjusting bolt will also come out so you can inspect everything.
Old Jun 25, 2010 | 07:57 AM
thanks bud! i'm going to go give this a shot right now.
anthonypazsd
135
Apr 2, 2026 12:56 PM
Steve_P
Jun 28, 2017 01:44 PM
Need4Spd
Automotosports - Illinois
14
Jun 19, 2009 08:55 PM
Lumpy
Lancer How Tos / Installations
Dec 18, 2007 01:51 PM
BLKRalliArt04
Jul 20, 2005 06:48 AM
