New ignition?
Old Nov 17, 2003 | 12:34 PM
Blacksheepdj's Avatar
New ignition?
After watching a show where they were rebuilding an old Chevy Nova and the host mentioned it, I was cruising through the Summit Sport Compact catalog and noticed a bunch of different ignition options (mostly MSD). I was just wondering if anyone has tried this or thought about it. I just ordered some Denso plugs and will be getting the Magnacore wires, and I was thinking that upgrading the entire ignition system was an option. What does everything think?
Old Nov 17, 2003 | 01:49 PM
pjal84's Avatar
https://www.evolutionm.net/forums/sh...t=msd+ignition
Nyope.
Old Nov 17, 2003 | 02:55 PM
Ah. I suppose searching beforehand would've been a good idea. Thanks for the answer!
Old Nov 17, 2003 | 07:14 PM
XTXANDY's Avatar
How about any way to upgrade the coils??? thats just off the top of my head, i was just thinking because if you upgrade the wires than two of the cylinders will have more spark than the others, or am I wrong thinking this (i'll do a search in a sec.. and when i find hte answer myself ya'll can just kick me thanks)
Old Nov 19, 2003 | 09:29 AM
thedeatons's Avatar
Check out Nology.com, they are local in San Diego, and they have awesome handmade wires, custom if needed, plus coil amps. I used the coil amps on a 1996 Kawasaki ZX-7R and it cleaned up the midrange a lot.... I also had the wires on it at the time... Anyway, great bunch of guys there, and they have come up with a kit to mount our coils on a special bracket, then have equal length wires running from each coil to the plugs!! They're testing on local Evos right now.... James
Old Nov 19, 2003 | 09:46 AM
uranium9v's Avatar
There is a turbo lancer here from Puerto Rico that totally removed the coils and ran 4 wires to the plugs through an ignition system. You'd need to be running the AEM EMS to get it to read and run correctly I believe.
Old Nov 20, 2003 | 10:57 AM
HobieKopek's Avatar
I'm not sure how the EMS handles its basic ignition setup. If I remember correctly it's a pretty simple "install wizard" type thing, but I set mine up for the second time about a month ago and I can't rightly remember anymore.
