Q's about gaskets and seals
Old Nov 18, 2003 | 10:14 PM
rhyzin's Avatar
so my question is, do i need to replace any gaskets or seals during a cam install, or can i reuse them? the ones mostly in question is the valve cover and cam oil seals(which i think are the only ones involved in the mod). but if there's others to consider, i'd like to her about it.
i've got the manual and basically it says i just remove the valve cover, disconnect the cam gear from the cam, remove the CPS, then the intake/exhaust rockers, then just slide out the cam.
if you've got experience in this sort of thing in general, i'm asking for some tips. i am pretty mechanically inclined and don't think i could foul this up at all, but any help would be great. thanks...
Old Nov 18, 2003 | 11:27 PM
pjal84's Avatar
When I had mine installed, everything was reused. No oil leaks or any funny behavior from the car so I'd have to imagine it'd be fine.
https://www.evolutionm.net/forums/sh...threadid=39007
Old Nov 19, 2003 | 11:00 AM
rhyzin's Avatar
all right, great! thanks pjal. did the search and couldn't find any specifics but this is good news for a diy like myself. thanks...
Old Nov 19, 2003 | 03:44 PM
fkrzo's Avatar
Just get that timming belt back on right!!!!
