Engine won't turn over
Old Aug 21, 2010 | 07:37 PM
Sea_Otter's Avatar
I rear ended someone in regards to someone slamming on their breaks in freeway traffic.
My buddy and I have taken apart the engine compartment trying to figure out why the engine will not turn over. Starter will not engage. Tested starter at Auto Zone and starter worked but the technician said it sounded weak.
We reinstalled starter and it wouldn't engage, had weak battery problems it seemed even with jumper cables. Not sure if that has anything to do with this situation.
Could it be the ECU or something we're missing?
Old Aug 27, 2010 | 05:52 AM
Sea_Otter's Avatar
Bump
Old Aug 27, 2010 | 07:17 PM
mci2727's Avatar
Yes it could be the ECU, could be that some wires got jacked in the wreck and shorted out and messed it up.
I would star by putting 12+ volts direct to the starter and see if that will turn it over, make sure first that you have a good ground connection to it and don't make the mistake of putting the 12+ to the ground connection on the starter.
If it doesn't turn over and you have good power to it, try wacking the starter with something pretty hard and try again.
If still nothing then replace it.
Old Aug 27, 2010 | 07:28 PM
mci2727's Avatar
No sure if you know how to do this...
Get the car jacked up on jack stands, find your starter and make sure you figure out which wire going to the starter is the ground and which one is the 12+ positive wire and then make sure your starter is connected good to the ground and take a jumper cable from your positive and touch it to your 12+ post on your starter and it should engage and turn the engin over, if it doesn't and you for sure have good power to it then you need to replace your starter.
P.S. It will spark so be careful!
Old Aug 28, 2010 | 09:50 AM
Sea_Otter's Avatar
Thanks for the tip.. we had the starter tested off the vehicle and it worked fine but on the car it wont engage. I'll try what you suggested though.
Old Sep 19, 2010 | 10:33 AM
Sea_Otter's Avatar
I ended up buying a new battery and starter, still won't turn over.
FlashEvolution
Jun 22, 2016 08:00 AM
Norske Marcus
Jan 23, 2016 02:43 AM
irving3d
Jul 7, 2014 07:18 PM
Brandon Robblee
Apr 5, 2014 10:01 AM
