Cams and such for 2.0/2.4 NA?
Old Oct 1, 2010 | 07:49 AM
M@verik's Avatar
Cost? About $1000. Installation? Depends where u get it done...
Old Oct 5, 2010 | 07:30 PM
Turbo1918's Avatar
hopefully Works gets them out soon.. Cams is something Ive been waiting on...More parts for the Lancer period.
Old Oct 6, 2010 | 05:25 PM
MD-09ES's Avatar
I emailed Works last night and they said that they arent sure on a release date but could be anywhere from the end of the year or the spring of 2011. I also asked them what they thought the expected gains would be but no response back yet.
Old Oct 6, 2010 | 06:27 PM
p1llar's Avatar
I hate to be a debbie downer but 180whp from a 2.0 even a 2.4 won't happen with out FI.
Old Oct 6, 2010 | 06:43 PM
Turbo1918's Avatar
true...
Old Oct 6, 2010 | 08:11 PM
Evo10HKS's Avatar
really? where did you get this assumption from.
last time i checked 2.4s dynod close to 160 at the wheels, works tune claims 18 to the wheels, so 178 from a tune + other mods. maybe you should do some more research. plenty 2.0 motors push 180whp without FI. so with cams 180 should be highly obtainable
Old Oct 6, 2010 | 10:24 PM
Stuntfly02's Avatar
Yes cams will greatly increase the upgrade potential of the lancers, and are something I have been waiting quite a while to see produced. However with that said I still think we have to do something about our air intake system to increase flow or just make the system more direct. I also think we need to break past the 6/6.5k rev limit on these engines. With some balancing and some higher compression pistons I really think our engine can become a high revving monster. Not entirely but I think you all know what I mean. We have perfect platform on the 2.0's, PERFECTLY square engine
Old Oct 7, 2010 | 12:14 AM
M@verik's Avatar
+1 A lot can come out of these engines and im glad that RPW and Works are attempting it.
Old Oct 7, 2010 | 06:15 AM
p1llar's Avatar
Show me ONE dyno with a 2.4 hitting higher than 145whp that's stock.
You can expect a 2.4 with a tune, intake, catback and header to hit mid 150's at best.
Don't get your hopes up for 18whp from a tune, that's be very generous to expect even from a boosted car like a evo or wrx. From a 4cyl. car running lean like ours, 3-5whp is more realistic with a different tq. curve. Just because a supplier says you'll gain "X WHP" doesn't deam it factual. Dyno charts from an unbiased source = proof to me.
I really do not think you've done your research on the 2.0 and 2.4
Old Oct 7, 2010 | 07:16 AM
ilovesaget's Avatar
Don't our cars run RICH from the factory?
Also, Evo's get far more than 18whp from a tune (coming from stock). From the dyno's I've seen, stock evos put down about 215whp stock and with a tune gain about 40-50whp. But apparently Evos run stupid rich from the factory.
Old Oct 7, 2010 | 10:15 AM
EngRWW33's Avatar
You are comparing apples and oranges... full bolt-on 2.4 with a tune I would imagine at about 170 whp TOPS on a high reading dyno.
Old Oct 7, 2010 | 10:35 AM
ilovesaget's Avatar
I agree. I was just disputing that an Evo would barely get 18whp from a tune.
Old Oct 7, 2010 | 12:27 PM
EngRWW33's Avatar
Evo's get 18whp EASY!!!
I think I am missing your point...
Old Oct 11, 2010 | 02:45 PM
Evo10HKS's Avatar
you are really making yourself look like a fool right now lol please do some research instead of talking out of your *** like some people tend to do on here
http://www.cardomain.com/ride/3116916/2
163tq, way above the BS you were stating, and the funniest statement out of your whole quote is you say 18whp is generous to get from a boosted car like a evo or wrx? LMAO. bro seriously before you post anymore, if you can find one evo or wrx that gets less than double that with a tune, then you shall get a cookie.
works is a very reputable company but with all the other crazy stuff you've said i wouldn't expect you to know much about works and their reputation. i would look up the comany and compare their dyno results to actual results from customers.
until then. keep up the research
Old Oct 11, 2010 | 03:00 PM
p1llar's Avatar
I'm quite surprised by those numbers, higher than I had antipated.
Here are some for the 4B11, which is much lower than that 4B12.
http://proje ctlancer.net/index.php?showtopic=47 (remove space)
What I was referring to about the tune, comparing a tune to a car that is NA to FI is comparing apples to oranges. You WONT see 18whp from a works tune on our car.
