Header tape
Old Jun 23, 2002 | 07:45 AM
WADADLIG_OZ's Avatar
Header tape
Can some one tell me if they have heard about a type of heat resistant tape that can be wrapped around headers? If so where can one buy some?
WADAD
Old Jun 23, 2002 | 07:47 AM
Lancer03's Avatar
yup, it think one compeny is DEI or something like that, go to summitracing.com and search there. you should find it there
Old Jun 23, 2002 | 07:55 AM
Lancer03's Avatar
Just open up there web page and do a keyword search for DEI, there are plenty to choose from, have fun.
Old Jun 23, 2002 | 08:03 AM
Thanks
That was quick
thanks for the replies
WADAD
Lancer03's Avatar
no problem, glad to help
Old Jun 23, 2002 | 10:23 AM
bahamut's Avatar
Be careful about header wraps . . . done wrong, you will crack it from trapped moisture. Talk to some DSM'ers who have use it . . . at least few have the experience with the product.
Since I don't have experience, I can't say anything.
BTW: I do believe TurboM on our board has used them. Email him about proper usage.
Old Jun 25, 2002 | 01:27 AM
dude in a mirage's Avatar
Follow the manufacturer's directions EXACTLY!!
For example with the DEI wrap you must overlap 1/4 of it (no more no less). Keep it tight, there should be zero gaps, zero loose parts. Also after it is wrapped you must then coat it with a hi-temp silicone spray (they usually handle some 1600degrees F). This will keep the metal from becoming damaged underneath. If you live in a humid area be very wary of using wraps and making sure you COMPLETELY coat the area with the silicone spray.
Old Jun 26, 2002 | 06:19 AM
Well Yes
You guys are scaring me.
I'll be moving to Orlando FL this weekend. Is that humid enough for ya?
I'll have to do some further research into this. Thanks for the warning.
WADAD
