Stock Air Box Question
Old Jun 27, 2002 | 12:41 AM
NicLancerOZ's Avatar
I have the RMR intake on order, but I was wondering...with the stock air box is there anything you can do to get better breathing out of it and make it louder?
Old Jun 27, 2002 | 12:48 AM
pjal84's Avatar
Why in the world would you want the stock air box to be louder? They're designed for ease of maintence, cost effectiveness, reliability and mass production. You could get a K&N drop-in panel filter (which I have) to replace the god awful stock panel filter (stupid cotton gauze). There was a slight increase in engine noise and gas mileage but what do you expect from a 4 cyl dumping out 120 at crank? Don't worry about trying to tweak that stock air box. Wouldn't be worth it especially if you've already ordered the RMR cone setup.
Old Jun 27, 2002 | 12:53 AM
importlancer's Avatar
Personally I would keep the stock airbox handy even after you recieve the intake for warrenty purposes...
If you need some work on the engine just slap that good ole' box back in there.
An I'm also with "P" on this one.. Can't see any reason to try an make your airbox any louder...
The K&N drop in filter as "P" meantioned will give you better airflow but as far as loudness wait for the intake itself.
Old Jun 27, 2002 | 12:59 AM
Well, I had heard that there is a resonator? on it, and some other things to constrict noise, and I wanted to take them off. I ordered the intake just today, so it will be a while until I receive it.
Old Jun 27, 2002 | 01:01 AM
Autobot's Avatar
Be careful removing the stock air box though. Me and about half the people here destroyed it or damaged it all to hell while trying to remove it. I guess I wouldn't make a very good obstitrician, huh?
cleofis's Avatar
i know this is off the topic..but how much did your intake cost?
Old Jun 27, 2002 | 01:07 AM
pjal84's Avatar
Originally posted by NicLancerOZ
Well, I had heard that there is a resonator? .
Resonator? Where? The stock equipment is the ram funnel above the radiator, the bottleneck pipe, the main filter housing, the filter, the MAS, then the tube leading to the throttle body. I don't see room for a resonator. Perhaps you heard resonator/diffuser mentioned in the thread about the intake manifold? If so, the theory is the bulge in the intake manifold on the left side (looking at the engine) could be a resonator, designed to disrupt airflow (quiter and probably affecting emissions as well).
Old Jun 27, 2002 | 01:11 AM
Onikun's Avatar
I paid 165 for mine at the mitsu dealership
wags528's Avatar
if you're in the mode to ruin the stock airbox you can always drill holes in it . . . . this would make it louder . . . i definitely would nto reccommend this, but i knew this kid who had a mid 90's protege and he drilled holes in his stock airbox . . . it sounded like he had an intake on it becasue it growled so mch, but i wouldnt consider doing this unless u want to trash the stock airbox . . . just wait for you RMR and you'll be fine . . .
Old Jun 27, 2002 | 01:13 AM
My RMR intake is $139 installed.
Old Jun 27, 2002 | 01:17 AM
wags528's Avatar
where did u get teh RMR intake for 139 installed . . . . i live in philly and i got my car in quakertown . . faulkner mitsu . . . the guy told me 175 shipped . . not including installation .. id install myself anyway . . . whered u get 139 in this area . . ill get it right now if i can find it for that cheap . . .
Old Jun 27, 2002 | 05:09 AM
Onikun's Avatar
It takes about 20-30 min to install try using vise grips and a second person to remove the mass airflow sensor! Very easy to do that way!
The actual hole where the air comes in is like 2 inches wide on the stock box! It amazing how small it is! The RMR intake does wonders for the way it sounds!
I would suggest keeping the box intact just incase. Although my Mitsu dealer said that adding the RMR Intake would not effect the warranty at all since the install it there also.
Old Jun 27, 2002 | 06:01 AM
LBLancerDude's Avatar
just take that long air scoup off... it'll be a bit louder... hardly though
Old Jun 27, 2002 | 09:10 AM
Yeah you remove the scoop you might get a tadbit more sound but think about the loss...
Scoop = Sucking of cold air from outside straight through the grille, through the scoop, to the airbox.
No Scoop = IMO you'd probally suck more hot air an drop performance for a little sound.
Old Jun 27, 2002 | 11:33 AM
alop's Avatar
Exclamation
You guys out east have it rough!! My friends in socal (where sport compact and import tuning practically was invented) get their parts cheap.
germanmike954
Jan 9, 2017 12:21 PM
EVIL_EV0
Apr 12, 2006 05:10 PM
ne evo
West Region
Mar 13, 2006 09:49 PM
asng
17
Aug 6, 2005 12:19 AM
