Megan Radiator on my 06 es
Old Feb 26, 2011 | 04:52 PM
jakermeister's Avatar
Just installed my Megan radiator boys! It was nearly a direct swap except for the aftermarket fans (wife wanted blue fans). It took about 3 hours to put in. I had to set it up as a push/pull set up. The right fan wouldn't fit infront. Its a lot better than that plastic looking set up. I would definitely recommend it. If your a automatic you'll have to run another tranny cooler. I just need another fan control modular. The fans only seem to turn on with the A/C on.
Old Mar 1, 2011 | 05:48 PM
Does anyone know where to get a fan control module online? The nearest dealership is a hour away (one direction).
Old Mar 2, 2011 | 12:40 AM
03lances's Avatar
Are you looking for #4 in this pic?
If so go here
http://www.mitsubishiparts.com/oe_parts_catalog.html
Put in your make model year then
Go under
-cooling
-radiator & components
-cooling fan
-control assy
I cant link straight to that page for some reason it just brings you to the beginning of the parts catalog
Old Mar 2, 2011 | 05:57 PM
Thanks man! I hope replacing the fan control module will fix the problem (fans only work with the A/C on). Anyone else have this problem before?
NickieBlaine
For Sale - Wheels / Tires
11
Apr 29, 2011 08:14 AM
NickieBlaine
For Sale - Cars For Sale
13
Apr 23, 2011 10:05 AM
poordude
10
Apr 6, 2010 05:00 PM
poordude
Midwest Region
Dec 28, 2009 02:34 PM
NickieBlaine
Nov 9, 2009 02:02 PM
