02 Lancer ES (A/T) Valves/Retainers/Springs/Head Gasket?
Old Feb 26, 2011 | 10:03 PM
JDM_CEDIA's Avatar
Im about 2 do my head gasket change. Is there any good performance head gasket/valve springs/forged valves/retainers for my ES (A/T)?
Fel-Pro Gasket is good?
Old Feb 26, 2011 | 10:19 PM
senate6268's Avatar
Originally Posted by JDM_CEDIA
Im about 2 do my head gasket change. Is there any good performance head gasket/valve springs/forged valves/Valve Springs for my ES (A/T)?
OEM Mitsu head gasket is the best to use. Unless you're running a larger profile cam, you don't need to run stiffer valve springs.
Old Feb 28, 2011 | 07:52 AM
lil' jeff's Avatar
just did mine and i would get the head resurfaced. i used some gasket set off ebay, mazimoto or something, no good it is leaking now so i'm not sure if the gasket is bad or block is warped, so i'm replacing entire drivetrain. get oem or fel-pro.
Old Mar 2, 2011 | 09:25 PM
JDM_CEDIA's Avatar
thanks team... making sure im doing the right way not some Mickey Mouse ****...
Black_EVO_MR
Nov 9, 2016 05:10 PM
drmcstford
Lancer Engine Tech
Dec 22, 2015 07:57 AM
Kojimagtrviii
May 24, 2014 06:15 PM
cmspaz
Jul 21, 2013 07:48 AM
White_KnightOZ
Lancer Engine Tech
Jun 6, 2009 11:49 PM
