evo x intake manifold
Old Mar 5, 2011 | 08:00 PM
dadsgts's Avatar
Well today i started the evo x intake manifold swap. Things went really well, however there was a few surprises. The manifold bolts up just fine. However since the evo x does not use a external egr valve the intake has nothing to incorpate one. So i did a egr delete, using thick guage alum i made a block off plate. Coolant line needed to be re-routed and the coolant line on the water neck was plugged.stock fuel rail does not work so i used a evo x fuel rail. Project will be done once 6an line for fuel return arrives from summit racing. Pictures will be posted once comlete. Btw i did not go the 4g69 throttle body route. I went with a 65mm eclipse gt 3.8 throttle body and port matched the intake manifold. Thats roughly 15mm larger then stock should make quite a diffrence for the turbo guys.
Old May 22, 2011 | 09:35 PM
BKGTS22's Avatar
Wow either everyone missed this thread or they're all waiting for pics lol this post got a lot more response in the other forum good **** dadgts hope it works for you so I can do the same for my custom setup
Old Nov 20, 2011 | 02:52 PM
BKGTS22's Avatar
Any updates on the manifold install?
Old Dec 19, 2011 | 09:02 PM
RoLLy's Avatar
He is MIA now, haha. He did my install back in November and his Lancer was gutted. He is working on an Eclipse now.
fostytou
359
Oct 23, 2025 09:54 AM
joseph143
Feb 19, 2014 07:42 AM
TTP Engineering
45
Dec 1, 2009 12:32 PM
R/TErnie
Nov 21, 2009 09:57 PM
