will the 2.4 bolt up to the 2.0 tranny
Old May 2, 2011 | 05:18 AM
08bluegts1's Avatar
Exactly what the topic says... I have to get a new engine and wondered if everything would fit and work the same... I was told it would and that the computer I have now will work for the 2.4.
Let me know please
Old May 2, 2011 | 05:45 AM
yitzac1990's Avatar
Who told you it would? i know the tranny on the 2.0 is the F5MBB. and your 2.0 ECU wont work unless you get it tuned for the 2.4 motor
Old May 2, 2011 | 06:39 AM
08bluegts1's Avatar
Well I'm turbo and run a custom tune anyways. Just need to know if transmissions are the same
Old May 2, 2011 | 09:29 AM
yitzac1990's Avatar
lol blew your motor, eh? not sure if transmissions are the same, im sure you could find it on the internet somewhere.
Old May 2, 2011 | 01:13 PM
08bluegts1's Avatar
Yeah I did lol.. well idk whats wrong with it. Just smokes real bad and lots of oil and some power loss. Repaired the turbo Nd didn't help. I'm guessing I either through a rod or a piston
Old May 2, 2011 | 03:01 PM
yitzac1990's Avatar
if you threw a rod or piston your motor would more than likely have a hole in it, and wouldnt start up at all. You should just find another used 2.0 and send it off to get sleeved and build it.
Old May 3, 2011 | 02:02 AM
M@verik's Avatar
Just get an outlander 4B12 and rebuild the 4B11 with its internals. As for the ecu, it will need to be retuned, but its not hard.
Old May 7, 2011 | 08:21 PM
graphiteralli09's Avatar
Sounds like you blew the head gasket and or cracked the block.
Old May 8, 2011 | 09:19 PM
villero1834's Avatar
i talk to dadgts about this already , the tranny and all the components bolted right on , the only problem that i have after my swap is that i have a cold start issue (needs tune) and my ac is not working , the belts are there and i can see the ac it self but i guess the dumb ****s that did the install forgot to plug it in i just didnt have time to check it yet
Old May 8, 2011 | 09:22 PM
str8kor's Avatar
as far as I know the 4g64 2.4L it will fit into a 2.0 tranny because ive seen guys do motor swaps from galants
Old May 8, 2011 | 09:30 PM
we are the new gen 4b1 engines but i guess is the same concept
Old May 8, 2011 | 09:34 PM
AndyCT9W's Avatar
I've seen different engines in the 4G (4G63, 4G93 etc) be paired with boxes that were from other 4G engines. e.g. transplanting 4G63T into a CK4A Lancer (former 4G92) and using the box from the old engine, done because 4G63 came from 4WD evo and CK4A is FWD.
Old May 8, 2011 | 09:36 PM
AndyCT9W's Avatar
Let me know please
Providing engine codes will be helpful. Mitsubishi have a few 2.0s, 4g63, 4b11, 4g61
Old May 8, 2011 | 11:10 PM
he has a 4b11
Old May 8, 2011 | 11:21 PM
AndyCT9W's Avatar
Ok, if the 2.4 is the 4g64 then I don't think it will unless you have a custom plate made. I've seen plates made to adapt a rotary engine to a 5 speed Subaru legacy box. And then I'm not sure the engine will line up properly with the box. Mind you I haven't tried it myself so I don't know, and anything is possible with enough time and money.
