Ralliart exhaust
Ralliart exhaust
I know you can install a ralliart or evo x muffler on a gts after modifying it, but would there be any gains or lost on doing this. Just dont want the ricer look or sound with one big muffler and trying to make my gts look like a ralliart.
no it doesnt have the dual exhaust look, if u have the body parts (ie the ralliart rear bumper) then i say go for the ralliart dual exhaust, if you have an aftermarket rear bumper made for dual exhaust beware that the ralliart dual is more centered than typical dual exit exhausts.
Ralliart and EVO X exhaust are not the correct size and not optimized for the lancer. You will likely lose power. If its too large or too small, the flow will either now flow because of the bends / restriction, or worse... overkill back pressure. Will your motor struggles to push the flow out the back.
Eclipse10358
May 23, 2014 10:31 AM
