Valve cover torque specs and pattern if any.
Hello, valve cover is leaking oil and after the shop wanted 200.00 bucks to re-do it, i found that all the bolts were loose. What is the torque spec's and pattern for the valve cover its-self? Thank you for your help, Dave
its like 3-4 ft lbs but you wont find a torque wrench that low but just start in the middle and work your way out. i always get em 1/4 turn past hand tight,it dont take much. might as well change the gasket though. its like 30in lbs
$200?! That is 10x the markup! The gasket alone is only $20. It's only a 30 minute job.
But like said earlier hand tighten. Feel how tight the others are. If you over tighten be ready to buy a new valve cover.
turboDan
86
Oct 26, 2012 12:47 AM
longdingydong
12
Jan 5, 2012 01:34 PM
