EGR Selenoid Valve?
Old Sep 15, 2012 | 01:52 PM
Beluga's Avatar
EGR Selenoid Valve?
I changed the catalytic converter and Vacuum Switching Valve -- EGR, cleared the computer and the Vacuum Switching Valve -- EGR is still showing an error (check engine light)?
It's possible the new valve is defective but not likely.
Any suggestions how to fix this?
Old Sep 15, 2012 | 06:59 PM
03lances's Avatar
Whats the error code?
Old Sep 28, 2012 | 07:47 PM
Beluga's Avatar
I changed EGR Vacuum Solenoid again with oem mitsubishi part and the code still shows up p-0403 showing an error with egr. Any suggestions what should I do?
Old Oct 30, 2012 | 08:52 AM
Automatic 51's Avatar
I had the engine light come on with the same code a couple years ago. Replaced the egr, cleared code but it came back on shortly thereafter. I took the intake and TB off so i could get to it easily and just sprayed carb cleaner in the egr ports and let it sit for a few min and after disconnecting the coil packs, crank the engine to flush out the carbon gunk. It will be a mess so be aware but 2 or 3 times on that and everything went back together and has worked perfectly for 4 years since.
Old Nov 1, 2012 | 08:06 AM
jwick76's Avatar
definitely, I hosed the ports on the block three different times and got in there with a wire brush and high pressure air spray. Clean out the gunk carbon deposits, as if it's clogged, nothing's getting to the EGR
fostytou
359
Oct 23, 2025 09:54 AM
kaj
Jul 30, 2016 02:39 PM
hotrod11686
Jul 1, 2016 10:28 AM
jxs1984
Oct 20, 2010 10:34 PM
phabaznbro
Apr 18, 2008 07:44 PM
