Nana gone bad
Old Oct 2, 2013 | 05:32 PM
wray0812's Avatar
Question Nana gone bad
i have an 02 lancer oz rally and my timing belt went out i have replaced fuel pump and relays tune up and it still wont fire sounds like its gonna but doesnt i did a compression test #1- 155PSI #2- 155PSI #3- 140PSI #4- 150PSI does it sound like its a crank or cam sensor or piston smack the valve can anyone tell me what i should try to check
Old Oct 2, 2013 | 07:32 PM
02modlanceroz's Avatar
Double Check the timing belt and make sure you aren't off a tooth or so. If that's good, make sure you plugged everything back in. If all checks out, good chance you bent a valve
Old Oct 2, 2013 | 08:00 PM
03lances's Avatar
Assuming you did the compression test after you did the timing belt I dont think you have a bent valve. That would severely drop the compression on 1 or more cylinders. Usually drops to zero or very close to since the valve no longer seals.
That being said I am with this^^ guy check your timing marks and all your electrical connections. If you can scan the vehicle and check for any trouble or pending codes.
Old Oct 4, 2013 | 08:00 PM
wray0812's Avatar
im gonna rip that side back down in the morning but how can i check the crank and cam sensors.
Old Oct 4, 2013 | 09:04 PM
03lances's Avatar
Unless they are physically damaged the only way to know if there is an issue with them is if you scan your vehicle.
Old Oct 5, 2013 | 12:27 AM
wray0812's Avatar
Ok that's right it would pop a code if they went out what do you think would be the best way to hold the harmonic balancer still
Old Oct 5, 2013 | 07:18 PM
03lances's Avatar
Use an impact gun to get the crank pulley bolt off. Gonna save you lots of time and potential damage.
Old Oct 5, 2013 | 07:27 PM
eusgen's Avatar
Yes this..
awda5fk
Sep 19, 2015 08:59 AM
evo panda
Oct 14, 2009 12:09 AM
CGroovy2k2
28
Nov 26, 2008 07:28 PM
Evo8
May 15, 2006 05:57 PM
mrdecibel
For Sale - Cars For Sale
14
Jun 9, 2005 10:24 AM
