I need help BAD!
Old Jun 9, 2014 | 09:26 PM
teammvm's Avatar
I need help BAD!
I have changed the thermostat, water pump, and flushed the antifreeze and replaced it with fresh antifreeze. My gauge is still fluctuating trying to touch red like it wants to over heat but doesn't then it goes down then back up and so forth.
Old Jun 9, 2014 | 10:21 PM
MR. EVO MR's Avatar
Did you burp everything?
Old Jun 10, 2014 | 03:12 AM
RT78's Avatar
If you burped the system and don't have any air pockets in it I'd try replacing the coolant temp sensor
Old Jun 10, 2014 | 07:29 AM
marcouxa1's Avatar
Looks alot like pockets of air in your antifreeze system. Open your radiator cap when the car is cold and let your car idle for 15-20 minutes with the heater on. Put something like a rag over your radiator because it might spill some antifreeze out when the bubbles come out. Once there is no more air bubbles after 15-20 minutes make sure you fill your radiator up to the cap with antifreeze.
dn788
Apr 17, 2017 10:13 AM
bruiselee
Apr 11, 2016 05:10 AM
tdanmorello
Lancer Engine Tech
Dec 10, 2008 07:49 PM
03redtype-s
Nov 3, 2006 06:35 PM
kam
13
May 8, 2005 08:52 AM
