247HP Supercharger Drive System for our Lancer??=)
Old Mar 30, 2004 | 09:44 PM
Viciouz's Avatar
i think somewhere 9 to 11 psi i am not shure...
Old Mar 30, 2004 | 09:50 PM
LancerDriven's Avatar
so when u push 9-11 psi through RRM dont you think you'll yield similar or better results? plus tq numbers will be a little better on a turbo vs sds cuz the belts rob from the engine.
Old Mar 30, 2004 | 10:03 PM
Viciouz's Avatar
i dunno... good question... but i think both kits have potential... i jus think that the sds has more tho
Old Mar 30, 2004 | 10:07 PM
liquidlancer's Avatar
ill belive 275 hp from ripp mods super charger when i. . . wait a minut ill never belive that. there is no way they are gettin those kind of number on the super charger with stock internals on a low boost number like 9 - 10 psi out of a device that uses power to make power. im sorry but even fi there was a dyno sheet posted ont eh forums id have to insist i was standing next to the car when it was being dynoed to belive that. say what you will or call me what you like but that is not belivable, nor possible
Old Mar 30, 2004 | 10:19 PM
quite the optomist i see...haha, good lookin out though i suppose. first of all obviously 275 is a crack number...still it seems a bit high...that's advertisement for ya!
Old Mar 30, 2004 | 10:20 PM
did i say crack? oh my....::eghem:: i meant crank
Old Mar 30, 2004 | 10:22 PM
crank or wheels 275 is just rediculas lol
(id still walk all over it)
Old Mar 30, 2004 | 10:23 PM
Iamkar33m's Avatar
Im taking a philosophy class in college which teaches logics and good / bad reasoning. The numbers RIPP is putting out and claiming you can acheive is just an empty promise to get you to buy the supercharger... I ain't falling for any stupid tricks like that. I wouldnt even believe a lancer can put out these kinda numbers with stock internals EVEN if I was standing right next to it at the dyno.
Old Mar 30, 2004 | 10:24 PM
HAHAHA so youd have to insist the dyno was broken or rigged hu?
I LIKE HIM!
Old Mar 30, 2004 | 10:26 PM
OZThunderGray03's Avatar
Superchargers are better for instant power because they run off a belt so are constantly running. Turbos need time to reel up since they run of the exhaust gasses
Old Mar 30, 2004 | 10:28 PM
ummm...i think we're a little past that...
Old Mar 30, 2004 | 10:36 PM
yea ans since they run off the belts thay add lots more rotating mass and drag to engine thus efectivle aking some of the "extra power" and throwing it right in the trash
edit: on another note turbo chargers hit full power much sooner then super chargers do
Old Mar 30, 2004 | 10:40 PM
Iamkar33m's Avatar
Superchargers are just a pain in the *** overall... #1 they are mainly for bigger displacement V6 and V8 engines since they use torque to make power. The smaller displacement engines really cant make as much torque as say a domestic muscle. #2 they dont boost as high as turbo's can. #3 even though they dont have turbo lag, they are pretty weak in terms of power outputted. Turbos can hit full power in as little as 1500 RPM if the right size is chosen. #4 they are incredibly expensive and also extremely high maintenance. Those belts are a pain in the *** to deal with.
So overall the turbo is more efficient for the money, power and size of the car. I rest my case.
Old Mar 30, 2004 | 10:48 PM
yeah...just cuz the supercarger's always running doesn't mean its running at full boost...there's no "turbo lag" per say, but its still running off of rpms...
Old Mar 30, 2004 | 11:02 PM
Viciouz's Avatar
wateva happened to blaze didn't he get the ripps sds... i want to talk to him about it... even tho i agree wid kareem on many points... but i'ld have to say u'ld prollie get more for you money thru the sds if the nubmers were true or even if they were a little less then that
