idle problems
Old Mar 27, 2004 | 08:39 AM
hollywood's Avatar
Angry idle problems
Hi guys, i hope everyones cars are running fine becuase i know mine isnt.
This question is for you mechanic heads out there. My car when it is idling at a stop will sit bewteen 500 and 700 on the rpm guage, but sometimes out of no where it will drop down to 400 or even 300 and then come back. and sometimes it will do the reverse- idle at 600 and jump to 700 or even 1000. ni am going to check all the plugs, and belts, and spark plugs today. if you guys can think of anything else that i should take a look at that would be great. Happy racing!!!
Old Mar 27, 2004 | 08:46 AM
dsmtuner23's Avatar
check if the mas air sensor plug became loose some how, if you have intake check at the couplers for leaks hope this helps
Old Mar 27, 2004 | 08:53 AM
hollywood's Avatar
right! i forgot about that. anything else anyone?
Old Mar 30, 2004 | 06:47 AM
hollywood's Avatar
I had talked to a friend and they had mentioned checking the timing? Does anyone know how to do this?
Old Apr 2, 2004 | 06:41 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Not sure about the timing, but since it's computer controlled, I would expect a CEL if that happens. Is this when the AC is on? Because mine idles differently (higher revs when the compressor turns on, lower when it turns off) when using the AC.
Old Apr 2, 2004 | 06:44 PM
lancerj's Avatar
i messed up the honeycomb in the mas and had to replace the whole thing after i tried putting an intake on. check that cause i could not idle right until i replace it.
Old Apr 5, 2004 | 03:02 PM
hollywood's Avatar
did u notice any serious power losses until you replaced it?
Old Sep 3, 2004 | 10:23 AM
jdmlancer1996's Avatar
abnormal idle rev
it is abnormal because of ur throttle body
there is a gear inside the throttle body that actuates the opening and closing of inlet of air inside the throttle body
here in philippines, there is a store where they modify throttle body. they buy surplus from japan and then they get what can they sell. they get the gears inside the surplus throttle body and put it in my throttle body. no need to buy a new throttle body and it just cost about P3000 = US$54
Old Sep 3, 2004 | 10:27 AM
Danno's Avatar
My car always has done that right from new. Yet when it is cold It idles at 2000 RPM. In the winter I dont even have to use the gas peddle to get my car moving (clutch fully disenguaged) I just figured it was normal.
Old Sep 9, 2004 | 12:56 PM
Jonas's Avatar
Yeah i'm having that same problem... but it only started to happen when i got an aftermarket exhaust put on... is there any way i can make it idle higher?
Old Sep 9, 2004 | 02:16 PM
pgmike's Avatar
man i have the same problem but when it changes rpms it makes a sort of a knocking sound.
Old Sep 9, 2004 | 03:42 PM
joshthegreat's Avatar
yep had thid problem two, it was my mass air flow sensor, the restrictoe plate came off and bent some of the honey comb stuff, check ur mass senor see if its ok.
Old Sep 9, 2004 | 08:19 PM
KUlancer's Avatar
cars run better in cooler, wet weather.... example.. the other morning there was a low cool fog. my car was moving really fast for a normal day... and then at noon it was hot as **** and the car barely rolled.
Old Sep 9, 2004 | 08:26 PM
4G63 Racer's Avatar
you need to check the clamps on your bov to if its not sealed right that could be a problem.
Old Sep 9, 2004 | 08:34 PM
petey pab's Avatar
^^^lol......bov........good one! check your idle control thingy on the throttle body. try raising the idle slightly and see what happens.
