idle low then dies?
Old May 12, 2016 | 03:00 PM
jb988's Avatar
How about a grounding issue? I found a a wire that was split open. It's the grounding wire for the horn of my alarm. But I have a worse problem now. Water started leaking from the ac system into the passenger side floorboard.
Old May 12, 2016 | 03:39 PM
Evox2008xove's Avatar
Did you figure this out?
Old May 12, 2016 | 05:37 PM
jb988's Avatar
Nope. It just kind of went away
Old May 12, 2016 | 10:26 PM
jimbo74's Avatar
Veteran: Air Force
water from the ac system? there is no water in the system, and unless it is condensing and your drain for it is damaged, are you sure it is water? and not a bad heater core?
Old May 13, 2016 | 10:27 AM
jb988's Avatar
I belive it has to do with the drain being clogged. I pulled the blower out and there was leaves in the cage
Old May 18, 2016 | 04:53 PM
Mrathb's Avatar
i used to have problem with my lancer when i put clutch in no matter what gear it would suddenly drop rpms and stall on me turns out my throttle value was very dirty but after a good clean worked perfectly again
STIU2SLO
Feb 14, 2017 02:21 AM
Toxin
15
Mar 14, 2009 12:47 PM
EVO8_PR
Sep 7, 2008 01:56 PM
NoTn41
10
Sep 19, 2007 11:43 PM
