HELP! Car Starts then dies after CAM install
Subscribe
Sep 18, 2007 | 07:24 PM
Here are the Problems (car was running perfectly before cam install)
1.When the MAS is plugged in with everything the car idles for about 2-3 seconds then dies.
2.When the MAS is NOT plugged it, the car will stay idleing
3. the car is giving 2 error codes
1. Error code 1: Camshaft sensor malfunction
2. Error code 2: Camshaft sensor circuit malfunction
A.Timing mark within limits.
B.Cams are at TDC (Top dead center)
Does anyone know what this would be?
Reply 0
Sep 18, 2007 | 10:22 PM
one idea is that the cam angle sensor was broken during install. is that a possibility with these symptoms?
Reply 0
Sep 19, 2007 | 01:55 AM
wow! sorry man that sucks
Reply 0
Sep 19, 2007 | 06:12 AM
Quote: one idea is that the cam angle sensor was broken during install. is that a possibility with these symptoms?
it sure is...
What kind of cams were these ?
By MAS, do you mean MAF ?
Have you tried spraying the inside of your MAF with brakecleen ?
You are going to need to find a new cam pos sensor and swap it out and see if it fixes it.
Reply 0
Sep 19, 2007 | 06:24 AM
Or maybe installed upside down...
Reply 0
Sep 19, 2007 | 09:16 AM
cosworth 272/272s
ya i meant MAF sorry.
i have not tried that. where do i spray the brakeclean exactly? the car only has 7k miles.
i dont know who i could swap one with.
Reply 0
Sep 19, 2007 | 09:40 AM
The CPS cant be installe dupside down, it has a 10mm screw that holds it in preventing just that. Is the tiny CPS ground wire connected?
Alfred
Reply 0
Sep 19, 2007 | 10:46 AM
Quote: The CPS cant be installe dupside down, it has a 10mm screw that holds it in preventing just that. Is the tiny CPS ground wire connected?
Alfred
The trigger on the end of the cam can be installed 180 degrees off (upside down).
-Paul
Reply 0
Sep 19, 2007 | 12:37 PM
Logged in wrong user
Reply 0
Sep 19, 2007 | 12:39 PM
You were running a blow through maf setup, now your running stock maf? When did you change it? If you didnt change it, your maftpro needs to be set up with the new cams to idle correctly.
Reply 0
Sep 19, 2007 | 11:43 PM
Alfred
the two sensors were swapped. we fixed the problem. Thanks for your help everyone
Reply 0
Subscribe
