Need help- 2 codes , car dies!!!
Old Dec 26, 2009 | 04:56 PM
evolutionEvo's Avatar
well on xmas started car to leave parents house let it idle for about 5 10 minutes , then it died!!!!!
car had three codes how do i test which sensor is bad???
p0340 - camshaft position sensor malfunction
p0335 - crankshaft position sensor malfunction
I cleared the faults and car started fine idled for a few minutes and the codes came back and car died again!!!!
any input please
Old Dec 26, 2009 | 05:01 PM
1d10t's Avatar
have a buddy with an evo near by?
Old Dec 26, 2009 | 05:11 PM
yes but ive been doing someresearch and am going to try a couple things first!!!! apparently some other people have had the same exact issues! but yeah ill prolly swap sensors if i cant fix the problem...
Old Dec 26, 2009 | 05:18 PM
evo8nfs's Avatar
its the cps sensor its 80 bucks easy fix just make should you dont put it in backwards... that will get you really fusterated unfortunantly it happens quite often
Old Dec 26, 2009 | 05:31 PM
^ yeah ima try getting a new battery alot said a dying battery can be the problem from my researching! and mines been giving me hard starts in the morning or if the car sits for a couple hours! if not off to mitsubishi on monday!
thanks for the input
Old Dec 26, 2009 | 06:33 PM
evo8nfs's Avatar
you know my evo been doin the same **** not wanting to start in the cold *** weather.. its really annoying, im scared to take it anyhwere being afraid it wont start...
Old Dec 26, 2009 | 08:00 PM
mine was starting to get bad last winter and i just dealt with it til now! lol its hard to start and when it starts the cams i have make it sound bad til it idles up a bit.
Old Dec 27, 2009 | 06:26 PM
Eric R287's Avatar
Check the Camshaft Position trigger. It's inside of the housing that the Camshaft Position Sensor bolts to.
My car also has cams and my trigger wheel came loose, causing the car to throw p0335 and p0340 codes. I re-aligned the wheel in the slots on the cam, tightened it back up, cleared the codes and it's good now. Probably should use loctite.
06' Evo IX
Mar 3, 2020 11:42 AM
wvrx
Nov 21, 2015 06:00 PM
CT9A PR
Oct 29, 2015 06:44 PM
DOUGLAS
14
Feb 3, 2009 07:00 PM
phatcat
Oct 20, 2003 04:26 PM
