Car will not start....pulled codes and need your input
Old Feb 2, 2009 | 08:03 PM
DOUGLAS's Avatar
P0340 Cam Position Sensor
P0335 Crankshaft Position Sensor
P0113 Intake Air temperature Sensor
My car died night before last after some on-going problems.....I pulled these codes tonight.....im confused as to how the cam and crankshaft sensor codes show at the same time.....the car turns over but will not fire....I checked the sensors and everything appears intact.....
I have been running an open hood vent so could moisture have caused a malfunction or short in the cam sensor?.....
heres a thread to my previous problems....sorry its long
https://www.evolutionm.net/forums/ev...lp-please.html
Old Feb 2, 2009 | 08:05 PM
burninrubb24's Avatar
check the connections sounds like they are not plugged in
Old Feb 2, 2009 | 09:24 PM
DOUGLAS's Avatar
they are plugged in.....
Old Feb 2, 2009 | 10:54 PM
mnbvcxz's Avatar
are you using an after market wire harness? that was one of my problems. those wires are cheaply made and began to come loose.
Old Feb 3, 2009 | 10:43 AM
DOUGLAS's Avatar
no sir...stock ecu flash tune.....
Old Feb 3, 2009 | 10:49 AM
evane's Avatar
try flashing your ecu back to the stock map and see if the codes go away???
Old Feb 3, 2009 | 12:55 PM
DOUGLAS's Avatar
I dont have a re-flash program but I cleared the codes through a scanner.....should I reset my ecu?.....Maybe moisture from me running no hood vent shield has caused this?.....
Old Feb 3, 2009 | 01:01 PM
Mad_SB's Avatar
I'm fairly sure these two:
will get set if the engine stalls out.
This one though:
indicates an issue with the maf, considering the temp sensor is in the maf.... probably would be a good idea to try and swap maf's with a buddy and see if that clears up the problem.
Took a quick look at your other thread and it def sounds like a maf issue (won't idle unless your foot is on the gas). My guess is that the maf screen is munched up and causing all kinds of screwy air flow reading, either that or it is just plain toast and needs to be replaced.
Old Feb 3, 2009 | 01:24 PM
DOUGLAS's Avatar
thanks man.....i appreciate your input....
Old Feb 3, 2009 | 01:38 PM
EvoHung's Avatar
I have heard of moisture setting those two codes off.. I had those codes about a month ago. After checking everything, it turns out to be my timing belt skipping a tooth or two. Not saying your timing belt is your problem, but its worth checking.
With that one, do what mad VIII suggested and try swapping with a friend.
Old Feb 3, 2009 | 03:05 PM
eVownd_IX's Avatar
i had a very similar problem.. for me it was my actual sensor if those cam positioning sensors are broken, all u will get is crank no turn-over and all i did was replace sensors and i was good to go
Old Feb 3, 2009 | 03:59 PM
scheides's Avatar
EvoM Moderator
Check the harness under the driver's side kick panel. Unplug all of the plugs, then pull all of the frontmost plugs out of the white frame they're in. Check for moisture and/or moisture damage. This will cause a no start.
Old Feb 3, 2009 | 04:48 PM
DOUGLAS's Avatar
thanks guys....I talked to a buddy who told me to check my timing......I'll get on all of this tomorrow or Friday for sure.....I'll keep you all updated.....
Thanks
Old Feb 3, 2009 | 06:59 PM
deathtracks's Avatar
Did it recently rain when you had this problem? If so I would go with what Scheides said. Search and you will find electrical gremlins from the grommet under the drivers side kick panel to be a common problem.
Old Feb 3, 2009 | 07:00 PM
850RCT9A's Avatar
Really sounds like timing. Let us know....
06' Evo IX
Mar 3, 2020 11:42 AM
michaellw
12
May 5, 2016 07:21 AM
JD7.62
Apr 7, 2008 08:59 AM
EVOclub4
Nov 13, 2007 06:41 PM
SLVROZ_03
Lancer Troubleshooting
13
Jul 28, 2007 11:35 AM
