reflash Lancer 05 4g94
Hi everybody, any have the xml file for read the rom on ecuflash???? i Attach the .hex file, and i test a lot xml, but not work, the values don't display correct information
I display somes values with 9753001.xml, but only rpm limit and injector size :-(
what model/trim is your car? is it USDM? JDM? manual or automatic?
does anyone have xml files for 4g94??? I’ve got my turbo set up on and am trying to use ecuflash but am stuck as ecuflash won’t read my ecu it keeps saying failing to connect and I was told I need the correct xml files. I have them for the 4g93 but don’t know if they’re the same
tonky333
Lancer Engine Management / Tuning Forums
Jan 10, 2021 08:24 PM
neddludd
Jun 12, 2020 05:37 AM
