Engine swap from automatic platform to manual platform - needed parts?
Old Sep 30, 2016 | 01:17 PM
Cameron Barlow's Avatar
Hello,
I'm brand new here, but not to Mitsubishi or vehicle performance / maintenance.
Here's one I should know, but I'm ashamed I don't.. I'm somewhat new to Lancers and my expertise really lies in the 4.6 Ford Modular line.
My 2003 Oz Rally is getting tired, and instead of a rebuild I'm planning a 57k engine swap out of a 2005 automatic ES. As far as I know, this is possible yes? Minus the clutch components of course.
Do they have interchangeable engine wiring harness connections, matching input shafts and spline count, same intake / throttle / MAF / etc? Of course I will do a visual inspection of the external engine parts and their similarities. But I would like to hear from a hardcore OZ Rally / 4G94 gearhead.
Thanks in advance,
-Cameron
Old Sep 30, 2016 | 10:17 PM
CrAnSwIcK's Avatar
The engines are identical, why are you concerned with the input shaft? The input shaft has nothing to do with the engine.
Old Oct 1, 2016 | 09:32 AM
I'm asking because I'm not too sure about the drivetrain on my OZ. Much more familiar with Fords. What I'm gathering is that the engine is 100% identical and doesn't have a slightly different setup for the automatic transmission?
Thanks
Old Oct 2, 2016 | 10:12 AM
CrAnSwIcK's Avatar
Thanks
The only thing that discriminates the transmission, is the transmission...you'll unbolt the flex plate from the crankshaft and replace it with a flywheel...that's all...ford is the same way. They are not at all related, the drive train has no effect on the engine block. Some different years/generations of the same engine code may have slight differences in intake and and exhaust design, but the block and head is always the same...same sensors, same locations...should all swap over no problem.
Old Oct 2, 2016 | 10:39 AM
I appreciate the quick reply. I should have been more specific with the details of my questions on compatibility. Just making sure the automatic platform wasn't using a crankshaft with a different spline count than the manual setup. I would imagine no automotive manufacturer would do such a thing right?
Thanks again,
-Cameron
Old Oct 2, 2016 | 04:17 PM
CrAnSwIcK's Avatar
There's no spline on the crankshaft...it's a bolt pattern, and I'm fairly certain no auto manufacturer's build their engines in a way that different transmissions would not be compatible.
Jmoney707
Apr 30, 2012 03:44 PM
evo_soul
Future Lancer / Evo Models
29
Dec 8, 2011 08:16 AM
Lancer1230
Lancer Tranny/Drivetrain Tech
36
Aug 28, 2009 09:15 AM
