2009 lancer gts throttle body
Old Nov 12, 2018 | 02:49 PM
02modlanceroz's Avatar
I'm running into an issue hopefully someone could shed some light on. I originally ordered a remanufactured throttle body with the same part number that's supposed to be on the car. After installing it I'm getting a P2135. If I swap my TPS from the original throttle body, all is good. I then decided to try a throttle body off of an 08 eclipse 4g69. Same exact issue as the sensor that came on the other remanufactured one. Now I noticed that the sensor is way bigger on the covers than the oem one. So has anyone had this happen, and is there a sensor I could buy that would actually work correctly?
Attached Thumbnails 2009 lancer gts throttle body-photo31.jpg   2009 lancer gts throttle body-photo961.jpg
