Idle/BISS Iac adjustmnet
Old Jun 22, 2020 | 05:14 PM
Nico13201's Avatar
Hi guys, i recently replaced a broken iac valve on my lancer 06 GLS 4g18 and after reseting the ecu and doing the relearn procedure it idles really high. messed with the BISS screw, now i think im f*cked. Any advice or a way i can set the BISS without a MUT?
Old Jun 23, 2020 | 07:36 PM
bumblebee.4G69's Avatar
5 Year Member
If the TB is anything like the 2008+ Lancer it's pretty simple stuff.
Easiest is to remove the black TPS cover with 4 screws and rove the idler gear between the butterfly and the DC motor
Once that is out you can move the butterfly buy hand with the half gear now exposed.
You can wind the gear back so the butterfly is closed and adjust the BISS screw from there.
Once it is adjusted so the butterfly is closed with out sticking , drop the idler gear back on , put the TPS cover and 4 screws back in.
Try it.
If the car has a spit
Leave the negative lead off the battery for about half hour.
While it's off
Turn the lights on to drain residual current.
Then lights off before reconnect battery.
All good to roll
Old Jun 23, 2020 | 08:06 PM
Nico13201's Avatar
I'm pretty I didn't understand what you meant, but the TB is quite different from 08+ Lancers. The TB i have are almost the same as 2g DSM TBs. I bought a clone Tactrix open port 2.0 and hopefully evoscan actuator works.
P.S sorry for my English.
Old Jun 24, 2020 | 05:37 AM
kaj's Avatar
kaj
With the Tactrix cable, you can read the IACV trims and adjust it properly. You are on the right track.
foxbat
Apr 5, 2015 04:05 PM
rm4g3d0n
Mar 31, 2015 07:25 PM
FunEvoguy
Apr 1, 2013 08:45 AM
SW20Mike
Aug 24, 2011 05:40 PM
lockadam2112
Apr 28, 2008 03:56 PM
