Wires to tap for the 02 Simulator?
Old Aug 23, 2004 | 12:57 PM
Dookie's Avatar
Hey all. I have the ESM but cant quite understand what wires I need to tap. There are two black wires, one blue and one white (Sensor connector side). Does anyone which wires are signal, 12+, and ground?
Also did a search but didnt find anything too definative.
Old Aug 23, 2004 | 03:38 PM
Dookie's Avatar
Just for info I think I figured it out. I decided to install the 02 simulator inside the vehicle under the shift console area and attach it to the harness there so it would stay out of the elements.
Red/Yellow: 12v+
Ground: Left side of shifter support (OEM ground already there)
White wire: Signal to ECU
So far so good. I will let you know if the light comes on in a few miles....Peace
Old Aug 23, 2004 | 06:49 PM
bigvinx's Avatar
what do you think about the sim ? and whare did you get it ? i keep blowin 02's beacuse of a problem with my ripp kit ! i just have to figure it out think a sim will help me ?
Old Aug 24, 2004 | 12:57 PM
joshthegreat's Avatar
hey dookie good stuff are you FI yet? im soon to be, you should really try and make it down to the meets yo
Old Aug 24, 2004 | 01:00 PM
blk02oz's Avatar
I am about to install some Kamikaze headers and may get a CEL so I was wandering where I can get this ESM ??? Thanks alot !
Old Aug 24, 2004 | 02:15 PM
Dookie's Avatar
You can get the ESM off of EBay for under $10. It doesnt do you much good because it tells you to removed the power steering pump bracket just to get the one lower left hand 14mm bolt off the header. I just put a 14mm combination wrench from under the header, then used a bigger combination wrench to pull up on. Also sprayed all the bolts down with WD-40 prior also. Don't know if it helped any though.
For the sim, I got it at www.o2simulator.com. It is working good and havent received a SES light yet. Just installed the header last night and the gains are real noticeable.
For the FI, still waiting on a dual gauge pod from lancershop.com. (The grey one.) I have the EGT wires routed already, and fuel pump swap, along with A/C fan swap is complete. I'll definately being going to the track soon. Late!
Old Aug 24, 2004 | 02:19 PM
blk02oz's Avatar
A/C fan swap ? Please elaborate.
Old Aug 24, 2004 | 04:28 PM
4g94T's Avatar
the ses usually comes on after 50 miles with the header on, how many miles did you run with the header on?
Old Aug 24, 2004 | 11:53 PM
Dookie's Avatar
In order for the RoadRace turbo to be installed, and actually for most other turbos that I know of, you have to take out the stock A/C fan to make room. Then you install an aftermarket one on the front side of the A/C condenser and it's a "push" air fan, rather than the stock one that draws air in.
Old Aug 24, 2004 | 11:54 PM
Dookie's Avatar
Its been a little over 50 miles. Nothing yet. Guess we will have to wait and see...I'll let you know how it works...
Old Aug 28, 2004 | 08:43 PM
VTECH8TR's Avatar
Dookie,
I have the same device with 100 miles and no SES light back yet. Will keep you guys posted to see what happens.
