new rims will they fit??
Old Nov 18, 2004 | 07:58 PM
ozrally05's Avatar
im getting 18 inch rims and i want to know if they fit.... im getting 18 x 7.5 with 215/35/18 and my car is lowered about 1.5"? will they fit okay thanks for all the help.. car is a lancer oz rally 02
Old Nov 18, 2004 | 08:03 PM
lookslikeanevo's Avatar
you might rub
Old Nov 18, 2004 | 08:06 PM
ozrally05's Avatar
yeah i thought so to but i have the stock rims that are 195/65 and they rub i lil right now so i think i will be fine. thanks though.. a lil rub never hurt.
Old Nov 18, 2004 | 08:16 PM
twardnw's Avatar
woah, are you sure you're only down 1.5"? which kit did you use? I'm down about the same and still on stock size tires, no rub atall
Old Nov 18, 2004 | 08:19 PM
ozrally05's Avatar
i bought it lowered from a guy.. it has shogun lowering springs on it...
Old Nov 19, 2004 | 02:49 PM
Phantom0's Avatar
yur screwed. The plastic firewall will need to be removed from your wheel wells. yur gonna wanna run with a 35 series tire, yur still gonna rub the fender outside. those 18's are gonna be too big. I got a 50 series tire on a 16 rim, the firewall needed to be cut so the rub would stop. i am lowered 1.8 all around.
Old Nov 19, 2004 | 03:28 PM
ghostrider's Avatar
We have several members in our club that have 18s and unless they absolutely slam the car (down more than 2") they don't have rubbing issues. Granted they have to take bumps slowly, but that's a given precaution.
Old Nov 19, 2004 | 05:54 PM
RobertK's Avatar
I have 18's and I rarely rub. just had to get re-alligned after I put the 18's on.
Old Nov 19, 2004 | 11:58 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Had you run a search (or even just stopped by the tires, WHEELS, brakes and suspension forum) you would have found this stickied thread...
https://www.evolutionm.net/forums/sh...ad.php?t=68953 (Everything you need to know about Rims and Tires)
And just like all of the other people who ask this question, you left out what is most likely the single most important spec in determining if those rims will fit...
What's the OFFSET of the rims? You want somewhere around a 42mm offset to avoid rubbing.
But yeah, plenty of people on here have lowered Lancers with 18s and 215/35/18 tires on them with little or no rubbing. It depends on the offset and the tires true width.
Old Nov 21, 2004 | 04:17 PM
ozrally05's Avatar
i finally got those rims and put them on.... i rarely run into rub at all only when turning with mild bumps but other than that rubbing is not a problem. thanks for all your help.
