Is my 4g94 engine worth moding?
Originally Posted by Evodreamer28
I am currently In the process of obtaining a turbo setup for my car. I am currently looking at a stage 3 turbo kit from Racing Performance Works. I would like for my engine to be sent out bored over and all the other work that needs to be done to handle the turbo setup. Does anyone know of any good places in the Northeast or even any outwest if I have to send it out?
Originally Posted by ROCK
Be carefull with NOS.
ROAD/RACE
ROAD/RACE
Well since I cannot bored out my engine do you have any ideas on what I should do motor wise because If I get the stage 3 turbo from Racing Performance Works I have the feeling I might blow up my engine.
forged pistons (but don't change compression if you're going turbo), bored throttle body and intake manifold, headers if you aren't worried about smog, catback exhaust, maybe a test pipe or high flow cat, get the ECU tuned. Anybody know if getting larger valves would help? And I'm sure Hobiekopek has tons more ideas, since he's actually done it.
Any other Ideas for pistons,cams, and anything else I might need to handle a turbo would also be helpful. I have had my lancer since January and I cant stand not having any power. Im trying to obtain as much information as I can to build myself one fast lancer Es. Any suggestions would be helpful.
Originally Posted by pgmike
https://www.evolutionm.net/forums/sh...ad.php?t=82017
you will find that using the search functuion will answer 99% of your questions so dont hesitate to use it first.
go here: https://www.evolutionm.net/forums/search.php
treat it like a normal search engine like yahoo. when you do your research, you will know who is more reliable, but many times, reliability in vendors/dealers is subjective and varies.
