How to get the exhaust pipe off???
Old Dec 2, 2004 | 07:19 PM
streetspeed's Avatar
I purchased the Buschur catback exhast system for my 02 Lancer Ls and was planning on installing it tonight. I managed to loosen the bolts connecting the muffler and I removed it. But, I can't manage to loosen the bolts connecting the exhaust pipe to the catalytic converter. How on earth did you guys get those bolts loose? I'd appreciate any suggestions.
Old Dec 2, 2004 | 07:21 PM
twardnw's Avatar
really really big breaker bar, you can use a socket over the end of the ratchet and then an extension on that to get leverage, you might try some thread cutting oil, or PB BLaster (check auto parts stores)
Old Dec 2, 2004 | 07:24 PM
I tried using some "liquid wrench" and attaching an extension for leverage, but those things are rusted on there so tightly that they don't even budge. Thanks for the suggestions though, any other ideas?
Old Dec 2, 2004 | 07:25 PM
twardnw's Avatar
impact gun, borrow or rent one in that case
Old Dec 2, 2004 | 07:30 PM
thanks I'll try that tomorrow.
Old Dec 2, 2004 | 08:33 PM
FlLancer's Avatar
After struggling for a few hours i realised i had an impact wrench.. that got it off in a few seconds.
Old Dec 3, 2004 | 03:28 AM
ghostrider's Avatar
Breaker bar for sure. I have one just for those bolts that's long enough to stick out from under the car.
Old Dec 3, 2004 | 07:34 AM
Blacksheepdj's Avatar
Haha. Florida pansies!
streetspeed - living in Ohio, I understand your pain. Those bolts are rusted TIGHT. Even the impact wrench wouldn't do it. To remove mine, I actually had to apply some heat (translation - blowtorch), and once the bolts were nice and hot, then hit them with the impact wrench. I hope you don't have to go to such extreme measures. Best of luck.
Old Dec 3, 2004 | 07:40 AM
camaro379ss's Avatar
i didn't even try to waste time with regular sockets, went staright to the impact wrench. Just make sure that u havent striiped any of the bolts yet because then it becomes a pain in the @$$!
Old Dec 3, 2004 | 08:00 AM
Shingen's Avatar
I had a really hard time with mine. I finally got them off with a lot of liquid wrench. WD-40 doesn't do jack, btw. Just let the liquid wrench set for about two hours and you'll be good to go. I took mine off with a wrench after applying the liquid wrench, no impact wrench needed.
Fox
Old Dec 3, 2004 | 12:58 PM
ItsTheDriver13's Avatar
From: Danville, CA (it really is all about nor cal)
you can always jsut cheat like we did in the ole auto shop in HS and take your socket, and put a piece of long steel pipe over the handle for leverage. prolly hard to do if you arent on a lift tho.....
Old Dec 3, 2004 | 01:08 PM
FlyTheFluffySky's Avatar
Sawz-All... JK
Breaker Bar and Rust Breaker.
Old Dec 3, 2004 | 01:25 PM
Thanks everyone, I will def. try these and hopefully my car will be driveable tonight!!
Old Dec 3, 2004 | 01:30 PM
Alchemist's Avatar
My solution last winter:
Propane torch gets bolts nearly red hot
Wait 30 seconds
Spray the hell out of it with the above mentioned PB Blaster
Impact gun
Pray you don't get hit in the head with a nut that's now several hundred degrees F (or the exhaust piping)
For that matter:
Pray you don't get hit in the head with a nut that belongs in your roommates boxers :wtf:
Old Dec 3, 2004 | 01:33 PM
.L.'s Avatar
.L.
Originally Posted by FlyTheFluffySky
Sawz-All... JK
LMAO
you should be fine with a breaker bar..... just let it soak in rust breaker/wd-40/etc. it should work.
