HELP! Part Numbers for TME GSR oils/fluids
Old Dec 16, 2001 | 09:08 PM
diyath's Avatar
Exclamation HELP! Part Numbers for TME GSR oils/fluids
I just completed the 15K km in my 6.5 TME GSR, and guess it's time to change the following. Would appreciate if someone can tell me the brands/part# for the following:
Model : Evo 6 TME GSR / RHD / Domestic Jap
(1) AYC Fluid
(2) Power Steering Oil
(3) Brake Oil (Brembo?)
(4) Transmission Oil
(5) Radiator Coolant
(6) Break Cleaner Spray
Old Dec 27, 2001 | 03:38 PM
Rogered's Avatar
Hello guys.
Answering a question from Diyath about part numbers for lubricants etc.
I haven't got any part No.s but I can give you specifications.
1. AYC:Their is two seperate places to put this fluid.One is in the rear diff itself(the plug facing towards the rear of the car),in here you require a ATF SPIII or Castrol Diaqueen. This fluid is also required in the hydraulic section of the system which is located in the boot(trunk) on the right hand side behind a little pull down flap. This fluid needs to be replaced in conjunction with a Mitsubishi MUTII(multi use tester)and the relevant ROM pack.
2. The rear differential,transfer box(front diff), and gearbox require Castrol Syntrax or equivelant to 75W90 gear oil.
3. For brake fluid I reccomend Castrol SRF(special racing fluid). This brake fluid has a higher boiling point, enabling heavier braking, and also extreme weather conditions.
4. Power steering fluid: I suggest ATS SPIII the same for the AYC unit.
5. Ant-freeze: Any anti-freeze that is recommended to you by friends,colleagues etc. is good for this purpose.
6. Brake spray: Again any spray that is recommended to you.
Also the engine oil filter part number is:MD 356000 (This is a part number).
I hope this is useful to you.
Old Dec 27, 2001 | 08:37 PM
diyath's Avatar
Thank you Roger. This is very uselful info for me.
Rgds
Diyath
fragmonkee
Mar 30, 2024 11:42 AM
TME96
Aug 9, 2016 12:09 AM
Mirrors
Australian Forum
May 31, 2016 06:22 AM
Mirrors
May 31, 2016 06:09 AM
kylecanthurdle
May 6, 2016 01:14 PM
