Glue?
Old Apr 15, 2005 | 09:56 AM
Sailorgoon's Avatar
Originally Posted by dignatary
The OZ have a 5 bolt pattern compared to the four bolt pattern of our ES's.
Incorrect. The OZ has a 4 lug pattern with a 114 offset. The LS also has this configuration.
The ES has a 4 lug pattern with a 100 offset. Stock OZ/LS wheels will not fit an ES.
EDIT: Back on topic
When my Accord's factory badging fell off, I used good old super glue. I'm sure it's not paint friendly, but the badge was on there another 2 rough Chicago winters, and was still there when I sold the car.
Lots of badging comes with double sided tape already installed. You might want to look into some of that. You can get it at Wal-Mart pretty cheap.
Old Apr 15, 2005 | 09:58 AM
TeamFlare's Avatar
But I'm sure I can buy the same 'style' rims for my offset.
Old Apr 15, 2005 | 10:00 AM
Sailorgoon's Avatar
Yes, OZ Chrono Evolutions. They're pretty expensive.
See my above post for a back on topic edit.
Old Apr 15, 2005 | 10:01 AM
TeamFlare's Avatar
I would get worried bout my paint using superglue.... but are you serious about double sided tape?
Old Apr 15, 2005 | 10:06 AM
Sailorgoon's Avatar
Totally serious. In fact, you might want to head to the dealer and see if they have any badges to show you. I'm pretty sure that the Euro EVOLUTION badges people have been getting use double sided tape.
I know a lot of aftermarket badging uses it.
Again, no promises on the paint. As for putting it back on in the first place, I can tell an ES when I see it, badges or not. People that have any clue at all will know that all the Lancer models are slow (02-03) and the little ES in the corner probably won't have any effect at all.
Worst case, if you really want it back on but are worried about paint and such, the dealer can get you a new badge for probably under 10 bucks.
Old Apr 15, 2005 | 10:08 AM
dignatary's Avatar
EDIT: Back on topic
Yeah wasnt totally sure on the bolt patterns but I new the others couldnt fit ... oh well you got my back!
Old Apr 15, 2005 | 10:15 AM
TeamFlare's Avatar
You're probably right... Plus it would just make my trunk look messier, I suppose.
Old Apr 15, 2005 | 02:28 PM
EdT's Avatar
EdT
The proper tape to use is a double sided acrylique grey foam based tape made by 3M, do do use regular carpet white foam tape. You should be able to find it at any automotive supply shop.
Old Apr 16, 2005 | 12:43 AM
arnold16890's Avatar
any double sided tape will do, i suppose..... but don't put the "ES" back on.... it looks ugly, i mean FUGLY ........ the ES badge wouldnt matter at all, people who knows car can tell your car is an ES right away, as Sailorgoon said. And people who doesn't know anything wouldn't even know ES is the cheaper type out of all lancers
