PCV line
Old May 30, 2005 | 04:02 PM
Supa tek's Avatar
PCV line
I just installed a Greddy oil catch can and my line from the pcv valve to the catch can seems to vacuum itself shut. To give you details.... I have an oversized line for the setup. I think there are 2 sizes available for the catch can setup and I got the larger of the 2 for a cheap price so I modded it to fit. There are no vacuum leaks and the line that goes from the catch can to the intake mani is fine. Any Ideas?
Old May 30, 2005 | 06:55 PM
Supa tek's Avatar
I checked the the valve and it seems fuctional. I'll get another one just incase. Any other ideas?
Old May 31, 2005 | 06:10 AM
brentg07's Avatar
Im confused a bit, you are saying that there is a valve on the line going from the pcv valve to the catch can, and it is shutting. If this is the case then it sounds like u have the valve on backwards. PCV should blow out oil and crap in to the catch can.
Old May 31, 2005 | 07:13 AM
Blacksheepdj's Avatar
You routed the PCV to the catch? I heard that was a no-no on N/A. I was told that I'd be pretty safe if I just used the EGR line.
Old May 31, 2005 | 01:39 PM
Supa tek's Avatar
I hear you there about the line shutting. But I'm positive its not on backwards....theres only one way it can go.
Old May 31, 2005 | 01:41 PM
Supa tek's Avatar
Are you serious? Why is that? I've never heard anything like that but it wouldnt be the first time.
Old Jun 1, 2005 | 10:14 AM
I think Boe told me it screws up the idle. But my memory is kinda fuzzy of that e-conversation.
