horsepower question
Old Jun 10, 2005 | 05:41 AM
livelyjay's Avatar
Be nice ... I sort of remember weighing 120lbs, I think I was in 7th grade or something.
The bottom line is both cars are slow as hell, so why even bother discussing this? Oh, and being automatic doesn't necessarily hurt in a drag race if the tranny can keep up with the horsepower and the driver knows how to make the computer shift. A friend of mine with an auto Maxima was killer at the track because he had the feel for his tranny down pat.
Old Jun 10, 2005 | 01:21 PM
Alchemist's Avatar
His fartcan may give you a distinct advantage. Excessively open exhausts generally do more harm than good. The problem is they reduce the low-rpm power by ridding the exhaust of the much-needed backpressure. They do afford the benefit of yielding tippy-top end gains (if any) Here, take a read (skim down to the exhaust section): http://www.pumaracing.co.uk/gentune.htm
The "best" aftermarket exhaust on the 4cyl lost only 1hp over the stock system.
exhaust has been discussed to death. The threads are old (early 04?) but they're there and this is a wheel that's not worth re-inventing
Old Jun 11, 2005 | 10:35 AM
arnold16890's Avatar
why does the site say " Every system cost at least twice as much as the standard one and the BEST of them gave 1 bhp LESS than standard." (http://www.pumaracing.co.uk/gentune.htm)
so aftermarket exhaust on a bone stock engine makes it worse?
Old Jun 11, 2005 | 10:39 AM
ambystom01's Avatar
Yes, a catback exhaust on the stock engine in question opened it up too much. For the lancer it could be different, but the general rules still apply, you have to design your exhaust for the nature of your engine, whether you need more back pressure or not.
chrls000171's Avatar
Originally Posted by arnold16890
well seriously, im not gonna race him cuz i have an auto and my frd has a manual.... and he has that farting missile launcher while i only have an intake.
Old Jun 11, 2005 | 02:02 PM
Alchemist's Avatar
If you read the rest of that paragraph, they go on to say how mags tned to only do "before" and "after" comparisons. Generally the cars they use don't have stock exhaust systems that are in optimal shape; they've got years of crud built up, maybe a hole, probably loose connections and in our cars the cats might be plugged, etc. The aftermarket systems are always brand new and give the appearance that they're making huge gains. In fact, here's the rest of the paragraph:
Originally Posted by http://www.pumaracing.co.uk/gentune.htm
Beware also of magazine tests that don't use a brand new standard system in a back to back test with a performance system. Because that costs money they usually just test the car as it comes for the "before" power run. If the standard system is already 5 years old, nearly rusted away and with silencer boxes clogged full of carbon then of course the performance system shows a gain - but so would a brand new standard system. It's not just "performance" systems that can be a waste of money. Some of the aftermarket standard replacement systems can be pretty dire too. They might look similar on the outside to the OE system they are designed to replace but have poorly designed silencer boxes that kill the flow and power stone dead.
Big bore systems can even hurt power quite a lot, especially at low rpm. I've fallen into that trap myself in my younger days. The OE manufacturers spend millions of pounds and several years in testing and development on their engines. The "performance" exhaust system manufacturers weld a few bits of tube together and spend a couple of grand on advertising. Who do you think has the best chance of getting it right? Copyright David Baker and Puma Race Engines
Old Jun 11, 2005 | 07:54 PM
modelchris's Avatar
Originally Posted by Slovak
HP isn't the most important factor in being fast, it is torque that is more important, because it is torque that gets you going, and HP that keeps you going once you get there.
okay, if this is the case, then why are ppl always talkin about HP this HP that, buy this intake, muffler, etc etc to increase HP? Not to sound like a dick, i'm just curoius....how do u incresae the Torque then?
Old Jun 11, 2005 | 08:19 PM
Z_Lancer_Man's Avatar
For one, the 4g94 intake manifold has longer runners, which helps increase low end torque. Thats one of the differences between the g93 and g94.
With that, would it be safe to say that our IM with a larger bore helps increase torque?
Old Jun 12, 2005 | 12:29 PM
ambystom01's Avatar
HP and torque are generally linked, so by increasing one you also increase the other in a specific part of the powerband. Basically torque is the engines ability to turn over, while HP is the engines ability to rev freely. If you've ever seen or driven a diesel land rover you'll understand why torque is so important and what affects it has on driving. Someone I know did an offroading course where they drove the diesels and the engine produced so much torque he did not need to use any gas to get the engine going, he could actually stand on the brake and let the clutch out and the truck would just sit there idling in gear.
Old Jun 12, 2005 | 08:48 PM
KasEVO8's Avatar
Word...... O_o
