Sticky Situation
Old Jun 24, 2005 | 07:24 PM
brains613's Avatar
Sticky Situation
I recently debadged the trunk of my 03 OZ. I was able to get the letters and OZ Rally sticker removed. But I can't seem to get the adhesive off. I have tried Goo Gone, WD-40, glass cleaner, and heating it enough to pull of. The stuff just won't budge!!! Any suggestions? Help me... the trunk of my g/f's ride looks like crap!
Old Jun 24, 2005 | 07:30 PM
StreetSleeper8's Avatar
im confused, your car or your gf's car?
mike
Old Jun 24, 2005 | 07:35 PM
oz4g94's Avatar
what did you use to heat it up? try using a hair drier (10-15min) and after you get all of it, or at least what you can, use a little turpatine to get the rest of it off (no it will not strip your paint-did exactly this to remove adhesive tape from my roof from satellite radio antenna). should work just fine.
Old Jun 24, 2005 | 08:09 PM
BigP436's Avatar
i use one of these at work, it just hooks into a grinder/drill and takes off the glue w/o hurting the paint
http://www.autobodysupply.net/store/...1-EFC47A090DBB
Old Jun 24, 2005 | 08:14 PM
brains613's Avatar
Mike, what difference does that make? Do you have something valid to add to the thread? If not, go jack someone else's....
Old Jun 24, 2005 | 08:15 PM
brains613's Avatar
For the record, car is registered to g/f. I make the payments.... G/f drives it primarily.... Feel better, Mike?
Old Jun 24, 2005 | 08:18 PM
brains613's Avatar
BigP,
There is a LOT of stuff on that page. Can you narrow it down a little? 'preciate the help so far...
Old Jun 24, 2005 | 08:27 PM
PGDlancer's Avatar
yeah BigP436, I would also like to know which one you use.
Old Jun 24, 2005 | 08:36 PM
BigP436's Avatar
sorry, i must have messed up the link, that part # is 07501, it should come up if u put that in the serch section
Old Jun 25, 2005 | 10:12 AM
comatose721's Avatar
i tried the heating an turpentine a while back and mine looks like crap...the glue still won't come all the way off. i hope yours turns out better than mine did.
Old Jun 25, 2005 | 10:14 AM
HobieKopek's Avatar
Clay bar, clay bar, clay bar.
Old Jun 25, 2005 | 10:16 AM
is this one of those things i can search? i've never heard of a clay bar?
Old Jun 25, 2005 | 10:20 AM
HobieKopek's Avatar
It's one of those things where this same thread was posted last week. A clay bar is a bar of clay (duh) used in detailing to remove imperfections from paint. It's somewhat abraisive, so it's used in conjunction with a spray bottle of soapy water.
Don't mind the price. There are much cheaper ones.
http://www.zainostore.com/Merchant2/...ory_Code=Zaino
EDIT: They claim theirs isn't abrasive. Go fig.
Old Jun 25, 2005 | 10:51 AM
sorry im trying to get better at this not asking dumb questions thing i'll run the search next time..thanks hobie...i'm a little bit slow
Old Jun 25, 2005 | 10:52 AM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
I'm surprised none of that stuff worked. I used WD40 and had no trouble getting it off. But it also dulled the paint in that spot. Seeing how many chemicals you used, I shudder to think of what your GF's is going to look like. As said above, clay bar is the only thing to use, unless you plan on repainting your car.
