02-03 Lancers *READ!!!*
wait stdreamy... explain the work in full detail pls! I've also had the noisy AC issue so I would like to get this fixed also... so is it recall or not? i'm still under waranty
Hey all its like he said , its the throw out bearing ... Mine has done it since about 8 months after i bought in in Dec 2002 . its more of an annoyance then anything as im sure we all agree. It makes no sense that its not covered , i mean i understand the wear and tear thing but a little catastrophic dont ya think ? Anyways if you guys cant get the dealer to do it under warranty dont worry bout anything else breaking. Just wait till you need a clutch and have them replace the bearing then.
Ok, to answer everyones questions....
1. it's for manuals ONLY
2. it's a throw out bearing that breaks rather easly on 02-03 lancers
3. i was told that it was covered under the powertrain warranty granted your warranty is still valid.
if you have any problems with that dealership, then you need to contact another dealership...
now a brief description of what it sounds like....
when the throw-out bearing breaks it starts to make a *clacking* noise..when you engage the clutch in idle it goes away, when you disengage in idle it comes back...now turn your ac on and it should get louder...
also, be warned....i've been told by one dealership that if they suspect foul play i.e. racing,drag racing..they'll void the warranty and charge you 800 bucks to have it repaired..so make sure you find a dealership that's no so harsh on that ****...i say call around and see what's up...then go from there...if you have any other questions feel free to hit me up...
i too have a "clacking" noise in my car when i first turn it on and when i turn on my a/c it gets even louder. also my car is an auto, you sure it's not also for auto's? X_X the noise really does get on my nerves but what can i say? no money = no fix > . < i can live with the noise but it's good to know more info on it ^_^
^^ Thanks, I'll try it and see, but sounds like mine is still ok. Just out of curiousity, what causes this to break?
i just changed my trowout bearing when i did my clutch and flywheel....and now it CLACKs horrible....i dont feel like changing it again....DAMMIT! fu(k u cheap MITSU parts....damn YOU!!!! ****in ****....did they redesign the through out bearing or what? if someone could describe what the fix is...
